Help with thickness planer?
Forum topic by watermark posted 03-02-2014 08:40 AM 1604 views 0 times favorited 11 replies Add to Favorites Watch
View watermark's profile
watermark
483 posts in 1938 days
03-02-2014 08:40 AM
Topic tags/keywords: planer
Last time I used my thickness planner (Delta 22-580) it chattered like crazy and I thought the problem was dull knives or the board I was running through was too short. I went and broke it down to check the condition of the knives and found wood chips jammed under one of the cutting knives.
The knife was broke when I pulled it off and now the locking plate is still bent from having the chip jammed under it.
Do I need to replace the locking plate to prevent the same thing from happening when I put new knives back on it?
If I do is 899306 PLATE-HEAD LOCKING part number 71 the right part?
All but 1 of the springs that are supposed to be under the locking plate were missing also. Are these needed if so any ideas on what part number they are from the above list?
Thanks
-- "He who has no dog, hunts with a cat" Portuguese proverb
11 replies so far
View mahdee's profile
mahdee
3883 posts in 1762 days
#1 posted 03-02-2014 10:32 AM
That looks like a serious bend. Likely cause; the screws locking the blade had com loose. Maybe go to Delta website and call them when ordering the parts.
-- earthartandfoods.com
View mrg's profile
mrg
823 posts in 2994 days
#2 posted 03-02-2014 01:36 PM
Looking at the diagram and your post the part over the blade is part 116, the springs are no longer available . If you click more info in the part number it will bring up other part numbers to cross reference to other like machines. The diagram says only two of the locks available and discontinued.
-- mrg
watermark
#3 posted 03-02-2014 07:55 PM
mrg- Thanks!!!! Your definitely right on that part number. I didn’t realize I could scroll down on the diagram.
mrjinx007- you might be right about the cause but the screws were all ceased up when I was taking it apart but that is probably just the pressure from the chip stuck under the blade.
View Dallas's profile
Dallas
3599 posts in 2482 days
#4 posted 03-02-2014 08:07 PM
If you decide not to fix it, I would be interested in buying some parts from it.
I have one with a broken gearbox that just begs me to rebuild it.
View Mainiac Matt 's profile
Mainiac Matt
8032 posts in 2323 days
#5 posted 03-02-2014 08:17 PM
Erepacementparts.com is another good place to check. It’s also likely that Sears parts direct may have it.
Google the exact OEM part number as there are several of these on-line parts places out there.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
runswithscissors
2750 posts in 2020 days
#6 posted 03-02-2014 11:36 PM
The springs you are missing are to push the blade up while you push it down with your blade setting gauge. If you can’t find OEM springs, try the spring out of a ball point pen.
mahdee
#7 posted 03-03-2014 12:58 AM
I have ordered some sears parts for my thickness planer and have been getting back order notices for 2 months now. Its not going to happen, I am sure of it. The tool is 23 years old and works fine hot wired.
watermark
#8 posted 03-03-2014 02:30 AM
Dallas- Thanks for the offer but I am going to try and keep it going looks like it’s will be around $90 in parts but still better then buying a new one… or another used one that comes with who know what kind of surprises. Just wish I could find all the parts in one place and save on shipping.
Dallas
#9 posted 03-03-2014 02:43 AM
Watermark- Yeah, that’s the way I feel about mine.
If I had the extra parts I would send them to you.
I collect parts everytime I find one because soon all of them will be on permanent back order..
In the meantime I use a little Craftsman that works pretty good, but it can’t hold a light to the 22-580.
View NormG's profile
NormG
6111 posts in 2999 days
#10 posted 03-03-2014 02:58 AM
You find all kinds of hings out when you take a machine apart for service, glad it is fixable
-- Norman - I never never make a mistake, I just change the design.
watermark
#11 posted 12-02-2014 04:59 AM
I finally got around to ordering parts and trying to get the planer up and running. Good news is the locking bar for the 22-590 fits this machine too. Bad news is infeed still isn’t working so I broke it down again today and found that the roller has worn about 1/8th of an inch in the center or heavily used area. $50 later should have a replacement in the mail in a couple of weeks. I have ordered the parts from acetoolrepar.com prices are fair and shipping was quick on the first order.
