Files
« back to Hand Tools forum
Forum topic by Gerald Thompson posted 03-01-2014 12:54 PM 982 views 0 times favorited 7 replies Add to Favorites Watch
Gerald Thompson
943 posts in 2235 days
03-01-2014 12:54 PM
I have two hand planes that require the mouths to be widened to accommodate Hock irons. I have read it is best to use a “safe edge file.” This meaning one with smooth sides. I have searched for these in the past and could not find anything that seemed as if it would fit the bill.
Any advice/help will be appreciated.
Thank you.
-- Jerry
7 replies so far
View Greg In Maryland's profile
Greg In Maryland
553 posts in 2999 days
#1 posted 03-01-2014 01:07 PM
You could always grind a safe edge on one of your files.
Greg
View Oldtool's profile
Oldtool
2624 posts in 2191 days
#2 posted 03-01-2014 01:08 PM
The only safe edge files I’m familiar with are the auger files: http://www.leevalley.com/US/wood/page.aspx?p=70693&cat=1,320,43072,43089,70693
Of course you could take a regular flat file to the grinder and make it a safe edge file.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
View Arminius's profile
Arminius
304 posts in 3804 days
#3 posted 03-01-2014 01:12 PM
Auger bit files are safe edge.
View lwllms's profile
lwllms
555 posts in 3282 days
#4 posted 03-01-2014 01:51 PM
Look for Swiss pattern pillar files.
Gerald Thompson
#5 posted 03-01-2014 03:09 PM
What is the difference between #0 and #2 cut?
-- Jerry
View Tim's profile
Tim
3807 posts in 1962 days
#6 posted 03-02-2014 02:25 AM
I can’t give a source on files with safe edges, but supposedly they are available in full size files. I’ve seen them in NOS at least.
Here’s a good source explaining the different cuts and how they correspond between American and Swiss pattern:
http://www.metalartspress.com/PDFs%20for%20MSKH/D%20--%20MSK-H%20--%20%20Chapter%204A%20--%20%20Filing%20&%20Grinding.pdf
TopamaxSurvivor
18272 posts in 3676 days
#7 posted 03-02-2014 04:30 AM
lwllms has the ones, pillar files. As Arminius says, auger bit files will have a safe edge, but a pillar file will be better suited to the task.
