Flocking the details
Forum topic by BubingaBill posted 02-27-2014 09:01 PM 1317 views 0 times favorited 21 replies Add to Favorites Watch
View BubingaBill's profile
BubingaBill
297 posts in 1922 days
02-27-2014 09:01 PM
Hi again gang,
I’m working on my latest cue case and after designing and building a custom jig, I was able to hot knife (out of Styrofoam blocks) tapered troughs for the pieces of the pool cue! In the past I did something along the same thing but I passed the foam over the hot knife.
The problem I discovered is applying a fabric to the foam is not a big deal when the trough is the same shape and depth from one end to the other. But now that is different and I’m foreseeing problems. I need this to look very professional so no wrinkles.
The Styrofoam is not high density but still pretty smooth. I’m thinking of using Flocking for the first time.
My questions are:
1. Will the adhesive eat the Styrofoam?
2. Will the flocking hide the super small imperfections in the material?
I don’t know if you guys have tried Flocking in this type of application but it’s worth asking!
Here is a few pictures of my jig and what I made. Notice the difference in the depths from one end to the other.
Thanks!
-- Measure twice and try not to cut your thumbs off!
21 replies so far
View madts's profile
madts
1884 posts in 2578 days
#1 posted 02-27-2014 10:02 PM
Are you talking about the spray on flocking, or the psa stuff.
-- Thor and Odin are still the greatest of Gods.
BubingaBill
#2 posted 02-27-2014 10:05 PM
I didn’t know there was 2 kinds!
I found a paint on adhesive that you “puff” on the flocking.
madts
#3 posted 02-27-2014 10:12 PM
You can go to just about any fabric store and they will have felt with a pressure sensitive adhesive on the back.
BubingaBill
#4 posted 02-27-2014 10:15 PM
I have concerns on how well that would stick to Styrofoam.
BubingaBill
#5 posted 02-27-2014 10:25 PM
I just searched the web and the adhesive for flocking is just Acrylic Paint and is fine for working with styrofoam! So my only question is Do you get a professional finish with the spray on flocking?? I have a 6” x 32” area I need to cover and I need to to hide the texture of styrofoam. I’m using black flocking if that matters.
madts
#6 posted 02-27-2014 10:28 PM
Try both and see what works best for you. You could seal the styro first.
BubingaBill
#7 posted 02-27-2014 10:31 PM
Seal it?
How??
I don’t want to make it brittle or give it a hard shell.
madts
#8 posted 02-27-2014 10:39 PM
What about an acrylic paint, or something like that.
BubingaBill
#9 posted 02-27-2014 10:43 PM
Sounds like a plan to me!
Thanks!!!
View Jim Finn's profile
Jim Finn
2688 posts in 3160 days
#10 posted 02-28-2014 03:22 AM
I do flocking on cedar and use acrylic paint and the puff-on rayon. (Oil paint also works) I need to thin the paint a little and put the paint on very thick to avoid brush marks so I think you would want to smooth out the stryo foam before flocking it.
-- No PHD just a DD214 Website> craftingcouple.com
BubingaBill
#11 posted 02-28-2014 03:40 AM
Thanks Jim. Any idea how to smooth the texture of the foam?
View jmartel's profile
jmartel
8279 posts in 2388 days
#12 posted 02-28-2014 04:20 AM
Bill,
What I would do for smoothing is to get yourself a can of bondo from an auto parts store. Skim coat it on, and sand it smooth. Then apply your flocking on that.
BubingaBill
#13 posted 02-28-2014 01:54 PM
J,
I thought about that but the whole idea of me using Styofoam was to have something soft with a bit of give to it. I have lots of experience with bondo and that would crack and break off if flexed.
I’m tossing around the idea of covering the flat surfaces with nice fabric and just flocking inside the troughs.
Jim Finn
#14 posted 02-28-2014 02:52 PM
I have not worked with Styrofoam so I am not sure how to fill in the voids on the surface. Some flexible glue maybe? Leaving it rough will give you a rough surface after flocking so I would experiment with some filler. White glue maybe? Fabric glue?
madts
#15 posted 02-28-2014 03:04 PM
What about white gluing some very sheer fabric to the styro. squeegee it down and then apply the flocking. I still thing the felt with the adhesive is the way to go.
