Which kinds of finish sit on the surface without penetrating?
Forum topic by HarveyDunn posted 02-27-2014 07:31 PM 1176 views 0 times favorited 9 replies Add to Favorites Watch
View HarveyDunn's profile
328 posts in 1662 days
02-27-2014 07:31 PM
I’m trying to sort through all my options for finishing a project. I want to carve through the dark finish on top to reveal the light, natural color of the wood underneath.
So my question is: which kinds of finish sit on the surface without soaking into the wood? Varnish is the one thing that comes to mind – but are there others?
9 replies so far
4906 posts in 2424 days
#1 posted 02-27-2014 07:37 PM
I think any of the film finishes meet your criteria, though at some very small level I think they all penetrate the wood just a little. But Shellac, lacquer and the waterbornes should all behave as you ask. Te stain/colorings may take some testing. Some are just pigments (sit on the surface) and some containing penetrating dyes.
#2 posted 02-27-2014 08:27 PM
Thanks. It occurs to me I should consider paint as well. I’m pretty sure flat acrylic would have the properties I want…what about oil paint? Will it penetrate? I’d probably buy “artist” paints, not house paint.
View bullhead1's profile
228 posts in 2180 days
#3 posted 02-27-2014 08:39 PM
I have a cnc and will put down a layer of shellac first and then use acrylic paint over the top before I carve. This way the paint doesn’t bleed into the surface.
View Clint Searl's profile
Clint Searl
1533 posts in 2292 days
#4 posted 02-27-2014 09:08 PM
No finish will penetrate more than about a millimeter, so use whatever you want: oil, clear film, or pigmented.
#5 posted 02-28-2014 06:08 PM
Thanks all.
bullhead, what do you use for a topcoat? I assume that you, like me, have some natural wood and some colored wood side-by-side but at different levels. Seems like I need something protective over them both but that won’t puddle unattractively in the lower, carved portions.
View Woodknack's profile (online now)
11293 posts in 2311 days
#6 posted 02-28-2014 06:21 PM
Lacquer is clearest and most neutral, then blonde shellac which is a tiny bit amber and waterbase poly which tends to be very slightly bluish.
-- Rick M,
#7 posted 02-28-2014 06:30 PM
I don’t have a spray gun. This is a small project – can I get away with spray can lacquer?
View Finisherman's profile
227 posts in 1780 days
#8 posted 02-28-2014 06:56 PM
For small projects, a spray can should be just the thing. Just make sure to get a good quality lacquer like Mohawk, Deft or Sherwin-Williams.
View oldnovice's profile
6666 posts in 3299 days
#9 posted 02-28-2014 07:01 PM
If you are going to a rattle can, use Deft lacquer. I have found this to be the best in spray cans.
