hollow grind on a parting tool or NOT?
« back to Woodturning forum
Forum topic by ken_c posted 02-27-2014 12:41 PM 1701 views 0 times favorited 11 replies Add to Favorites Watch
View ken_c's profile
ken_c
324 posts in 3277 days
02-27-2014 12:41 PM
what is the consensus, do we put a hollow grind on a parting tool or not? be it a diamond, thin or flat, hollow grind or no?
11 replies so far
View Nubsnstubs's profile
Nubsnstubs
1359 posts in 1845 days
#1 posted 02-27-2014 01:50 PM
If I understand Hollow Ground, you can’t help but put it on a parting tool if your using a round grinding wheel….. ........ Jerry (in Tucson)
View DIYaholic's profile
DIYaholic
19647 posts in 2790 days
#2 posted 02-27-2014 02:00 PM
I use my 8” grinding wheel, so….
I’d say, yes???
View dogmir's profile
dogmir
25 posts in 2087 days
#3 posted 02-27-2014 02:18 PM
As stated if you are you going to sharpen it on a grinder it will happen. That is just he nature of using a grinder. However a parting tool is something you could sharpen with a variety of other methods to maintain a flat grind. Personally I don’t find myself grinding my parting tool all that often. I usually just hone it quick with a DMT diamond stone. I learned that from Alan Lacer. He uses that method to touch up skews. It works just as good for a parting tool in my opinion.
View TheDane's profile
TheDane
5515 posts in 3778 days
#4 posted 02-27-2014 02:57 PM
It is macht nichts to me … I used to sharpen mine on a belt sander, but had to use a wheel when I took it to seminar. Since then, I just use the wheel & tool rest.
ken_c
#5 posted 02-27-2014 03:32 PM
Ok Dane, thanks, since you have done both and aside from convenience which do you like better and why? I just got a new 1/8 flat side( not diamond) parting tool. I already had 3/16 diamond tool which I took to a wet wheel and now is hollow ground. I use a tormek, but for this tool I paused and I am trying to understand what if any advantage will be gained by going hollow or not.
View waho6o9's profile
waho6o9
8347 posts in 2692 days
#6 posted 02-27-2014 04:01 PM
No hollow ground on this type of parting tool:
Yes to a hollow ground on this type of parting tool:
If I understand you correctly. You can grind and make your own tools as well.
That’s what I do when duplicates.
HTH
TheDane
#7 posted 02-27-2014 05:05 PM
ken_c—Don’t have a preference. I don’t see any advantage either way.
I don’t like wasting steel, so I will keep on using the wheel … no sense in re-grinding them again.
View davidmackv's profile
davidmackv
317 posts in 1763 days
#8 posted 02-28-2014 12:08 AM
I sharpen my parting tool on my belt sander.
View jumbojack's profile
jumbojack
1681 posts in 2739 days
#9 posted 02-28-2014 12:45 AM
disc grinder for the parting tool. Us Shopsmith owners even have a jig available to sharpen most of our turning tools on the disc. BUAHAHAHAH
View JollyGreen67's profile
JollyGreen67
1676 posts in 2878 days
#10 posted 02-28-2014 01:44 AM
Doesn’t make any difference – I’ve done it both ways. If it’s hollow grind, then you can hone.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
ken_c
#11 posted 02-28-2014 11:19 AM
thanks all. i will use a flat diamond hone until that becomes to time consuming then, to the wheel…
