OK power carvers
Forum topic by sgv posted 02-27-2014 12:20 AM 1312 views 0 times favorited 10 replies Add to Favorites Watch
View sgv's profile
sgv
266 posts in 1921 days
02-27-2014 12:20 AM
OK power carvers, I was thinking about getting a Foredom wood carving kit. I have used a Dremel ( the same one for 30 years !! got my moneys worth out of it)This weekend it died. I carve small birds,sand,grind with it but want to start doing some larger carvings, and adding detail to my bowls. The question is is it worth the money??? any one use them? Do you like it?
Thanks all
SGV
-- Tite Lines, May the wind be at your back
10 replies so far
View JAAune's profile
JAAune
1802 posts in 2345 days
#1 posted 02-27-2014 12:43 AM
Do you happen to have an air compressor with good CFM? If so, an air-powered pencil grinder is an option. Harbor Freight has a cheap one but even more expensive brands could be had for the same or less dollars as a Foredom kit.
View bigblockyeti's profile
bigblockyeti
5140 posts in 1749 days
#2 posted 02-27-2014 12:56 AM
I bought a 4 1/2” BAD BLADE for my angle grinder. Works better than I expected for $20. Definitely want to have the guard on when using this, cuts through hardwood like a hot knife through butter, would go through flesh even easier.
View Jim Finn's profile
Jim Finn
2658 posts in 2951 days
#3 posted 02-27-2014 02:50 PM
I have a tool that uses Foredom tips called a Mastercarver. Looks and works just like a Foredom. Wecheer is yet another good brand. I got the one with a variable speed on the bench, not a foot pedal that one has to hold down all the time. (That is tiring) I have three hand pieces for this tool. Small rotary, large rotary and a carving tool that I like a lot. It works like a miniature jack hammer to carve with different small gouges. Much lighter and easier to use than a Dremel.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View PaulDoug's profile
PaulDoug
1550 posts in 1732 days
#4 posted 02-27-2014 03:48 PM
I’m really interested in what the responses are here. I also want to step up from a Dremel. I got my dremel off e-bay for $30 and it has served me well, and still is, but I’d like to have better. I’ve been looking at the Foredom for over a year now. Just hesitant to fork over the money.
View koraile's profile
koraile
98 posts in 1690 days
#5 posted 02-27-2014 03:57 PM
This was wery interesting, im considering doing bigger sculptures, what kind of accesories setts do you get for theese bigger machines?? anyone have any links. Its the diversity on carving heads on the dremel that makes it so Nice, even do i would wish there was a even bigger assortment of them.
-- Bard son of iver
View sgv's profile
sgv
#6 posted 02-27-2014 10:39 PM
Thanks to All (I do need to make a choice soon) 8-)
View SurfHunter's profile
SurfHunter
54 posts in 2442 days
#7 posted 02-28-2014 01:26 AM
I’m going to keep an eye on this thread, because I’m interested myself.
I was looking at the SCM 400xs it’s 400,000 rpm’s and its seems pretty awesome, and very easy.
Not sure if its against the rules to post links. But if so Please fogive me.
http://www.scmsysteminc.com/engraving.php
https://www.youtube.com/watch?v=U1JK6aODkUM
-- It’s not the hours you put in, but what you put into the hours that count.
Jim Finn
#8 posted 02-28-2014 03:14 AM
http://www.woodcarverssupply.com/Flexshaft-tools/products/18/ This is where I get my stuff.
koraile
#9 posted 03-01-2014 08:23 PM
Some of those was pretty Nice, thanks. Think i have to putt this one on my wishlist of Things to get:)
-- Bard son of iver
View Ocelot's profile
Ocelot
1981 posts in 2667 days
#10 posted 03-02-2014 02:46 AM
I picked up a flex-shaft carving tool from HF a few years ago, but never figured out what to do with it. It’s one of those hanbing type – probably with a pedal, but I’ve never taken it out of the box. Don’t have any burrs to use with it either. I’d love to try that thing if I knew what to do with it. They don’t carry that model anymore.
