Bench Top Planer/Jointer 2 Questions
Forum topic by Steve Kreins posted 02-26-2014 08:34 PM 1089 views 0 times favorited 6 replies Add to Favorites Watch
View Steve Kreins's profile
Steve Kreins
358 posts in 1534 days
02-26-2014 08:34 PM
Topic tags/keywords: question planer jointer
1. I get the Planer part of this ‘Combo” but can someone explain the “Jointer” part?
2. I think my nitch is moving towards cutting boards, boxes and tables. I want my cutting board pieces very straight and parallel prior to glue up. Would a tool like this be a good idea for prepping my pieces prior to glue up ?
Not necessarily this sears one, but one like it.
-- I thank God for everything, especially all of you!
View dbhost's profile
dbhost
5686 posts in 3135 days
#1 posted 02-26-2014 08:47 PM
The tool you are showing a photo of is a jointer, and it is a useful tool in the shop. Not 100% required, but I like mine and plan on keeping it…
If I had to chose between a planer, OR a jointer, I will go with the planer every time.
If you look at the Wood Whisperer videos, particulary the one “The Jointers Jumpin” you can see you can joint with a planer, but you can’t plane with a jointer…
You can check out my review of my Ryobi planer. Not a great machine, not terrible, certainly easy on the budget.
http://lumberjocks.com/reviews/1638
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#2 posted 02-27-2014 02:09 AM
Yep, that’s a jointer and it doesn’t like end grain any better than the planer!
A drum sander is the best tool for flattening end grain cutting boards (and a lot of other things as well).
View Picken5's profile
Picken5
250 posts in 2595 days
#3 posted 02-28-2014 06:05 AM
Agreed — that’s a jointer. Some, however, will still refer to it (incorrectly) as a planer. And, I’m going to disagree with Dave’s comment “you can joint with a planer” (sorry, Dave). You can use a jointer to flatten one face of a board and the jointer is used in Step 1 of the 4-Step lumber milling process described by the Wood Whisperer in Jointer's Jumpin'. But another very important use for the jointer is to ensure that the edges of 2 boards you want to glue together are truly straight & flat. Without that, it’d be pretty hard to make a table top — or a face-grain cutting board for that matter. I don’t know of any way (well, not a safe way) to joint an edge of a board with a planer.
(Granted, however, many will use a router to joint edges — and some will swear a table saw works fine for that. I agree with the router method, but it’s way easier on a jointer IMHO.)
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
View jdh122's profile (online now)
jdh122
981 posts in 2721 days
#4 posted 02-28-2014 11:49 AM
What Howard said. Except that I think that in the UK (and possibly the rest of the non-North American English speaking world) they call that a planer and what we call a planer is a thicknesser to them.
I don’t know about that model, but I had a benchtop jointer before and it was a heap of junk. Maybe different brands work better than the one I had, but the tables are so short that it’s hard to get straight glue surfaces from it. If you have the space, you can probably get a new entry-level full-size 6-inch jointer for $150 more than the benchtop one. I’d strongly recommend you think about it.
-- Jeremy, in the Acadian forests
Steve Kreins
#5 posted 02-28-2014 01:28 PM
Thanks for all the input! I’ve decided this would not be a good addition to my shop. I have a 12 1/2 planer I just need to be careful as to how I use it. It was really the word jointer that threw me and got me currious.
Thanks as always you guys are great!
View lumberjoe's profile
lumberjoe
2894 posts in 2151 days
#6 posted 02-28-2014 01:46 PM
So maybe you didn’t actually watch the video, but Dbhost is 100% correct. You absolutely can flatten a board with a planer. You can’t just run it through an expect it to be flat. You need to use a sled.
A planer is infinity more useful than a jointer. There are many easy alternatives to both face and edge jointing – planer sleds, router planes/jigs, hand tools – etc. There really isn’t an easy way to thickness a board without a planer.
