Forum topic by airfieldman | posted 02-26-2014 04:27 AM | 1316 views | 0 times favorited | 9 replies | ![]() |
I need help. I can’t seem to keep my blades clean. As seen in the photo. I’m simply stumped. Am I doing something wrong or is this common. If it’s me, what is it I’m doing. If it’s common, what do you do to correct it? -- Measure with a micrometer, mark with a crayon, cut it with a chainsaw. |
9 replies so far
#1 posted 02-26-2014 01:25 PM |
Looks like you have too many teeth/inch for the thickness of the material you are cutting, and/or it is a gummy material that is sticking in the tooth gullets. Either way I suggest switching to a blade with the same width but half the tooth/inch count and a “Skip Tooth” profile. That will increase the gullet area between the teeth and give the sawdust somewhere to go as you cut. The object here is to give the sawdust room between the teeth and not pack it into the gullets. For efficient cutting with a band saw you want to have a blade with a tooth count that puts at least three teeth into the thickness of the stock you are cutting, but at the same time you want the teeth as large as possible without sacrificing the quality of the cut. -- Minnesota Woodworkers Guild, Past President, Lifetime member. |
#2 posted 02-26-2014 01:44 PM |
What Hydro said, get a skip tooth blade. -- Bondo Gaposis |
#3 posted 02-26-2014 01:57 PM |
Are you cutting 2×4’s maybe? I ran a bunch thru for a friend, took me 2 weeks to get my blade back to clean. Yes, you have too many teeth, but I think you also have gummy wood. -- Dan V. in Indy |
#4 posted 02-26-2014 04:49 PM |
Thanks all…That makes sense. I was using this for making reindeer. The one’s you cut on two sides of a block and end up with a caricature of the beast. There are some very tight radii so I needed a narrow blade. Dan, you said it took a while to get the blade clean. How? -- Measure with a micrometer, mark with a crayon, cut it with a chainsaw. |
#5 posted 02-26-2014 09:22 PM |
Mineral spirits and a brass brush, but that was really slow. Then I ran it thru a little bees wax block, that made it look terrible! Thought I was going to have to buy a new blade. But then, I ran some oak thru, resawn, it got warm, the wax came off, and pulled a lot of the sap with it. Eventually, it has returned to a like new condition. FWIW- this Carter blade is the first 1/2 blade I’ve owned that I would have gone to the trouble to save. I have had great luck with it, and it cuts straight as an arrow. I did some band saw boxes a few years back, used a Timber Wolf, small with many teeth. Only got three boxes out of that blade. And it was slow cutting, push too hard and it would turn the blade. -- Dan V. in Indy |
#6 posted 02-26-2014 09:56 PM |
To clean a blade, fold it up and soak it in a pan of household ammonia overnight. Be sure to cover the pan to contain the fumes. The sap will dissolve away without any scrubbing. To fold a blade, check this link: http://www.youtube.com/watch?v=Z45BIMQ3WlM -- Minnesota Woodworkers Guild, Past President, Lifetime member. |
#7 posted 02-26-2014 10:26 PM |
OK! Get the right blade, when it needs cleaning soak in a warm water solution of Arm & Hammer WASHING SODA. Didja get that it was SODA instead of baking soda? Brush the blade with a parts washing brush, and get back to work. -- bill@magraphics.us |
#8 posted 02-27-2014 12:47 AM |
This is great advice. Now I have 3 ways to chose from. Being the lazy natured guy that I am, I would expect to go the easy, soak overnight and be done. But, since we don’t keep ammonia in the house, maybe not. I do like idea of enviro-friendly. But the brushing sounds monotonous. Thanks everyone. -- Measure with a micrometer, mark with a crayon, cut it with a chainsaw. |
#9 posted 02-27-2014 02:29 AM |
Hydro’s advice can’t be improved on. For cleaning, I soak mine overnight in the purple formula “Simple Green” and spray them off with water the next morning. Sparkling! I clean my drum sander belts the same way. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4909 |
6697 |
28075 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6236 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
