Panel glue-ups - Do you assume that cleanup and flattening is required?
Forum topic by paxorion posted 02-25-2014 08:58 PM 779 views 0 times favorited 2 replies Add to Favorites Watch
View paxorion's profile
paxorion
1107 posts in 2067 days
02-25-2014 08:58 PM
Topic tags/keywords: question joining
As I’ve gotten more and more woodworking projects under my belt, I find that panel glue-ups have been my third most “hated” part of projects (behind sanding and finishing). The reason I “hate” glue-ups is that I feel like I’m stressing myself needlessly by chasing a pipe dream of perfect edge alignment. During my project, I find that I have gotten significantly better in achieving better results because…
  1. I’ve gotten much better at properly milling my material S4S so that when placed flat dry, I see zero gaps
  2. Parallel clamps have proven to work exceptionally well with panel glue-ups
  3. The use of cauls have helped with alignment
  4. A dry run of the glue-ups help me understand what to expect, so the actual glue-up goes smoothly
My question is, do others find panel glue-ups as frustrating as I do? Or am I needlessly causing my to blood pressure to shoot up when I should be OK with some scraping/sanding to flatten the panel glue-ups?
-- paxorion
2 replies so far
View woodchuckerNJ's profile
woodchuckerNJ
1276 posts in 1656 days
#1 posted 02-25-2014 09:04 PM
I don’t stress over them.
I mostly use parallel clamps, but also employ 4 sided clamps too.
You don’t even need square sides, just complimentary angles.
And I usually employ a bit of spring in my joints if I am jointing during more humid months.
I stress more over finishing.
-- Jeff NJ
View Bill White's profile
Bill White
4947 posts in 3982 days
#2 posted 02-25-2014 09:05 PM
Yep. Some scraping/sanding should be expected. Don’t worry. Be happy. Where have I heard that before?
Bill
-- bill@magraphics.us
