Thickness planer vs. Jointer
Forum topic by woodengolfer posted 02-25-2014 07:42 PM 1330 views 0 times favorited 11 replies Add to Favorites Watch
View woodengolfer's profile
woodengolfer
9 posts in 2099 days
02-25-2014 07:42 PM
I have the basic tools…. table saw, compound mitre saw, as well as hand power tools, drills,sanders,biscuit jointer etc. In considering my next tool purchase, I am looking at either a thickness planer or a jointer, but am uncertain as to which tool would serve me best.
Most of my projects to this point have been ones that I can use dimensional S4S lumber. However I now want to move into projects where lumber would need to be sized down from dimensional lumber.
I would appreciate any feedback on which tool you would recommend purchasing first
11 replies so far
View bondogaposis's profile
bondogaposis
4754 posts in 2373 days
#1 posted 02-25-2014 07:52 PM
I recommend a thickness planer. There are more work arounds for a joiner than planer.
-- Bondo Gaposis
View DIYaholic's profile
DIYaholic
19623 posts in 2697 days
#2 posted 02-25-2014 07:54 PM
There are many an opinion on this issue….
I would get a thickness planer first. There are several work arounds for not having a jointer.
There are jigs & fixtures that will allow you to accomplish much of what the jointer is used for.
There are tons of people that do not have a jointer and do not regret it.
View CharlesA's profile
CharlesA
3329 posts in 1819 days
#3 posted 02-25-2014 08:00 PM
+1. You can use rough sawn lumber with a planer and workarounds (jigs, planes, or a combination). It’s what I do. I’d be interested to hear of someone who only used a jointer and not a thickness planer.
View jmartel's profile
jmartel
7950 posts in 2172 days
#4 posted 02-25-2014 08:00 PM
Planer.
View pintodeluxe's profile
pintodeluxe
5701 posts in 2835 days
#5 posted 02-25-2014 08:03 PM
To work with rough cut lumber you need a jointer to flatten one face, then square an adjacent edge. That is followed up with planing to thickness.
However since you want to start with S4S lumber, all you need is a thickness planer and a tablesaw.
Ultimately a jointer is a handy tool to have. Even my S4S lumber gets a fresh edge at the jointer before I cut my stock to size. It is a pleasure to make projects with straight, square lumber every time.
View lepelerin's profile
lepelerin
495 posts in 2347 days
#6 posted 02-25-2014 08:10 PM
there are many similar post on this forum. You can use your planer as a jointer with the help of jigs.
I would go with a planer first.
View Gene Howe's profile
Gene Howe
10519 posts in 3450 days
#7 posted 02-25-2014 09:05 PM
A well tuned table saw with the proper blade and a straight piece of plywood will allow you to trim rough or crooked lumber well enough to rip it further. The same goes for a circular saw, which is my first choice. And, any piece whose width doesn’t exceed the height capacity of the planer can be jointed. So, go for the planer first.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3607 days
#8 posted 02-25-2014 09:44 PM
I use my thicknesser nearly always despite owning a combo planer thicknesser machine.And like I believe a very famous rocker chair maker hardly or in his case never use the jointer what we call a planer. So I say a thicknesser will be much more useful to you.Alistair
18351 posts in 1878 days
#9 posted 02-26-2014 02:49 AM
No doubt, it’s a planer. If you’re gonna get just one, but the two go well together also.
View EPJartisan's profile
EPJartisan
1118 posts in 3147 days
#10 posted 02-26-2014 03:24 AM
If not redundant….I vote for a planer as well. I estimate that I use my planer 10 times more often than the jointer
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
View knotscott's profile
knotscott
8055 posts in 3397 days
#11 posted 02-26-2014 10:05 AM
Both is best….the two are extraordinary in tandem, but for starters I’d go with the planer and a planer sled, then would edge joint with a TS or router until I could afford the jointer.
