Band Saw Tensioning
Forum topic by Charlie75 posted 02-24-2014 06:49 AM 839 views 0 times favorited 5 replies Add to Favorites Watch
View Charlie75's profile
Charlie75
312 posts in 2264 days
02-24-2014 06:49 AM
I am always at a loss as to how much to tension a band saw. I know there are a lot of theories out there. I am a tad paranoid I guess having broken one blade and not anxious to repeat the experience.
If memory serves me I even read a statement (not on this forum) that it would almost impossible to tighten a blade with the normal knob enough to break the blade. I have my doubts about that.
Just for information I am talking mainly about a 3/16 blade on the Chraftsman 14” saw. I have a Carter stabilizer on this saw also. I might add that on occation the blade with jump out of the track in the stabilizer. Any thoughts?
Charlie
-- Charlie75, Alto
5 replies so far
View pintodeluxe's profile
pintodeluxe
5661 posts in 2813 days
#1 posted 02-24-2014 07:35 AM
Just snug it up so there is minimal deflection of the blade when you press on it with your finger. If the blade is sharp, and I cut slowly, I have found my bandsaw actually cuts better with moderate blade tension.
Charlie75
#2 posted 02-24-2014 11:10 AM
Thanks pintodeluxe. Appreciate your reply.
-- Charlie75, Alto
View bonesbr549's profile
bonesbr549
1549 posts in 3067 days
#3 posted 02-24-2014 03:37 PM
I’ve used the flutter method for years and never had it fail. Google bandsaw flutter method. It will give you all the info you need. I never spend more than 2 min getting a blade right on install.
View gfadvm's profile
gfadvm
14940 posts in 2690 days
#4 posted 02-25-2014 01:35 AM
The above tensioning advice should get you where you need to be. Remember that the Stabilizer needs to be set farther forward than a normal thrust bearing to keep the blade from jumping out of the bearing groove. I set my Stabilizer1/8-3/16” in front of the back edge of the blade (after the blade is tensioned).
Charlie75
#5 posted 02-25-2014 02:10 AM
gfadvm, That’s about where I keep mine. I think I am probably ok now with tensioning.
-- Charlie75, Alto
