Finish for oak and cherry
Forum topic by shipmodel posted 02-23-2014 10:53 PM 939 views 0 times favorited 5 replies Add to Favorites Watch
View shipmodel's profile
3 posts in 1490 days
02-23-2014 10:53 PM
Topic tags/keywords: question cherry oak finishing
Hello! This is my project, I make ship models. I have very big problem with finishing of the wood . I try so much things and didn’t like the result. Everything is with some yellow color that is not what I want. And the pores are so visible, I think that is too much for this project. I have so many products , , and i don’t know how to make right combination. Or maybe this are not right products , I don’t know. The variants that have are two light or dark to be down , , , I need a advice how to reach this effect to the oak . With what kind of products,methods, what is the technology to reach this kind of effects?
This is how the colors look like now Thank you for reading :)
5 replies so far
View madts's profile
1854 posts in 2276 days
#1 posted 02-23-2014 11:14 PM
I think you need a sealer. I also have built models and was never happy until I used a sealer of some sort. Even BLO works good but takes a long time to dry.
-- Thor and Odin are still the greatest of Gods.
View paxorion's profile
1107 posts in 1982 days
#2 posted 02-24-2014 04:20 PM
Perhaps a pore filler like Timbermate?
-- paxorion
View Clint Searl's profile
Clint Searl
1533 posts in 2298 days
#3 posted 02-24-2014 09:20 PM
The color will darken somewhat regardless of the finish, but a waterborne poly will darken the least and doesn’t have a yellow cast.
#4 posted 02-27-2014 04:18 PM
Thank you about answers :) I will read , and research your suggestions :), if is possible for you to show me some pictures of the effects , this will be very helpful for me. Thank you.
View DavidIN's profile
81 posts in 1924 days
#5 posted 03-02-2014 01:31 PM
if you use an oil finish you can put it on and sand it with 400 to 600 grit wet/dry sandpaper while wet, as soon as you apply it, and it will somewhat fill the pores with the slurry it makes. it is best to practice on some scrap for sure. don’t practice on your finished piece, it is very nice. if you want a non yellowing finish try lacquer, spray can should be good for that size. Try a couple of coats of lacquer, 0000 steel wool and then apply a coat of wax on a scrap piece. you can even get colored waxes.
