Polyurethane Over Spar Varnish?
Forum topic by Ron Ford posted 02-23-2014 05:24 PM 9684 views 0 times favorited 10 replies Add to Favorites Watch
View Ron Ford's profile
Ron Ford
208 posts in 1759 days
02-23-2014 05:24 PM
Topic tags/keywords: question
I just finished turning a segmented bowl that includes a number of pieces of redheart. I gave it a coat of sanding sealer, followed by a coat of spar varnish for its’ UV-resistant protection to keep the redheart from turning brown. Since spar varnish only comes in clear gloss, can I scuff it when it dries and apply a coat of satin polyurethane (or any other satin finish that anyone may recommend) over it?
Thanks,
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
10 replies so far
View Mark Kornell's profile
Mark Kornell
1169 posts in 2557 days
#1 posted 02-24-2014 12:44 AM
Yes, you could. Or you could just rub the spar to a satin sheen using steel wool.
-- Mark Kornell, Kornell Wood Design
Ron Ford
#2 posted 02-24-2014 12:53 AM
I hadn’t thought of that option, but it sure makes sense. I assume 0000 steel wool is the proper grade?
Thanks,
Ron
Mark Kornell
#3 posted 02-24-2014 07:19 AM
Yup, 0000. Use a lubricant, too. Make sure the spar is completely dry or it won’t be hard enough to get an even sheen. Lots of articles on the net, but try http://www.woodworkersjournal.com/Main/Articles/Rubbing-Out-The-Final-Step-to-a-Great-Finish-5261.aspx
Ron Ford
#4 posted 02-24-2014 02:10 PM
Thanks again, Mark. I appreciate the advice, and the article you directed me to was also very helpful.
I gave the bowl the first coat of spar varnish yesterday. I think I will let it dry another day before I give it another coat, then let it sit for a week or more before I try any further rubbing.
Ron
View woodchuckerNJ's profile
woodchuckerNJ
1276 posts in 1660 days
#5 posted 02-28-2014 01:08 PM
You realize that spar is for outdoors. It does not harden like poly.
Not sure how poly over spar is going to be, as the spar is softer your finish may not last long if you put poly over it.
I’m not certain, just pointing that out as a possibility that you may want to check out.
-- Jeff NJ
HillbillyShooter
5811 posts in 2319 days
#6 posted 02-28-2014 01:17 PM
I wouldn’t for the reasons pointed out by Jeff—hard finish over a soft one.
View 49er's profile
49er
171 posts in 1631 days
#7 posted 02-28-2014 02:51 PM
Thanks for the link Mark.
-- Correlation is not causation but I did loose my Doctor !!!
View Bill White's profile
Bill White
4949 posts in 3987 days
#8 posted 02-28-2014 03:04 PM
Wait more than a week before final rub-out. When it stops smelling like varnish it is cured and ready to rub.
Bill
-- bill@magraphics.us
View whope's profile
whope
142 posts in 2472 days
#9 posted 06-18-2014 03:34 PM
Ron,
How did this turn out?
Bill
-- Measure it with a micrometer, mark it with chalk, cut it with an axe.
Ron Ford
#10 posted 06-18-2014 06:29 PM
Hi Bill – It worked out just fine. The finishes worked well together, and the colors of the wood are staying bright and vibrant.
Ron
