Gluing Rubber Mat To Plywood?
Forum topic by Steve Kreins posted 02-23-2014 03:01 PM 3282 views 0 times favorited 4 replies Add to Favorites Watch
View Steve Kreins's profile
Steve Kreins
358 posts in 1865 days
02-23-2014 03:01 PM
Topic tags/keywords: question gluing rubberwood
I’m building a front load washer and dryer pedestal for my wife. I bought some 1/8 rubber mat material and didn’t think to buy any contact cement. FYI the mat is to dampen any vibration and reduce noise, also added protection against moisture..
QUESTION: Would Titebond II be OK to use or should I wait until I can get some contact cement? Or is there a better way to attach it?It’s area is 60×32.
Thanks as always for the help!
-- I thank God for everything, especially all of you!
View JL7's profile
JL7
8692 posts in 3199 days
#1 posted 02-23-2014 03:05 PM
I doubt that TB II will do…...
Contact cement should work, depends on the type of rubber. I would roughen up the rubber mat with sandpaper before gluing. Superglue also bonds rubber well.
-- Jeff .... Minnesota, USA
View tyvekboy's profile
tyvekboy
1829 posts in 3247 days
#2 posted 02-23-2014 03:12 PM
Steve
Where are you putting the rubber mat? Between the pedestal and washer/dryer or between the floor and the pedestal?
First, letʻs assume you are putting it between the pedestal and the washer/dryer. I wouldnʻt use the whole mat since each machine only has 4 feet that will make contact with the pedestal. I would think a 4 inch square for each foot would do. I would also opt out for contact cement or spray adhesive. You could also use double-sided fiber reinforced indoor-outdoor carpet tape.
Iʻm so cheap, I would have cut up some old mouse pads (of which I have a lot from trade shows back in the 80ʻs) and use those too.
Hope this helps.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View levan's profile
levan
472 posts in 3214 days
#3 posted 02-23-2014 03:13 PM
I have never done anything like this, but I wonder if you could just nail or screw the perimeter w/o the glue.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View Lee Barker's profile
Lee Barker
2170 posts in 3085 days
#4 posted 02-23-2014 04:49 PM
Try the Titebond in a sample setting. You don’t need much adhesion in that application.
Another approach would be construction adhesive applied with a notched trowel.
Kindly,
