Where to start with milling down very rough cut lumber.
Forum topic by CH53ECC posted 02-22-2014 09:32 PM 985 views 0 times favorited 11 replies Add to Favorites Watch
View CH53ECC's profile
CH53ECC
16 posts in 1483 days
02-22-2014 09:32 PM
I am helping a friend mill down some cottonwood and not sure where to start. It was cut down with a chainsaw to roughly 7” square boards 6’ long. The sides are not perfectly parallel to each other and rather rough from the chainsaw cuts. Can I run this through the planer and slowly work my way down then to the jointer? I have never worked with this rough of a cut only the store bought rough cut lumber that doesn’t need nearly as much work.
11 replies so far
View Don W's profile
Don W
18610 posts in 2477 days
#1 posted 02-22-2014 09:39 PM
Do you plan to resaw it into 1x or are you making post/beams?
If you are re-sawing, what are you resawing with?
CH53ECC
#2 posted 02-22-2014 09:44 PM
I would like to get it down 1×6 -1×5. I have a jointer, planer, table saw, and circular saw to work with.
Don W
#3 posted 02-22-2014 09:53 PM
I think you have a dilemma. The only tool you have that can work a 7” piece is the planer (unless you’ve got an 8” jointer)
You could make a sled and run it through 2 sides to get it down to 5”. but that’s a lot of waste. (then resaw with the tablesaw or skil saw) definitely not ideal.
Where are you located. Do you know anybody with a bandsaw or bandsaw mill. That would be the easiest.
View JAAune's profile
JAAune
1780 posts in 2226 days
#4 posted 02-22-2014 10:04 PM
I use a jigsaw to cross cut rough lumber about 4” long and a bandsaw to rip it at least an 1/8” over-sized. From there it goes to the jointer to flatten one face then the planer to mill it to final thickness. The last thing to do is joint one edge on the jointer and rip to final width.
View bondogaposis's profile
bondogaposis
4611 posts in 2260 days
#5 posted 02-22-2014 10:23 PM
The only reasonable tool that would handle making boards from this large of a cant is a bandsaw.
-- Bondo Gaposis
116913 posts in 3486 days
#6 posted 02-22-2014 10:31 PM
Here’s one way to joint wide boards
http://lumberjocks.com/tenontim/blog/26637
View OSU55's profile
OSU55
1524 posts in 1899 days
#7 posted 02-22-2014 10:31 PM
To get 1” thick material from 7” – bandsaw or a mill with a large diameter blade. Find someone with a bandsaw or portable bandsaw mill like a Woodmizer. Here in Missouri some folks advertise in the “materials” section of Craigslist that they will saw lumber, so you might check your area.
Don W
#8 posted 02-22-2014 10:34 PM
If your ambitious you could snap a line on each side, cut it with the skil saw, then finish it with a hand saw.
CH53ECC
#9 posted 02-22-2014 10:35 PM
Looks like I’ll be looking for a band saw. The tree was cut down 7 months ago and has been outside here in nevada so it has been pretty dry. Anything I need to know about moisture and if it is dry enough to start on?
CH53ECC
#10 posted 02-22-2014 10:37 PM
I’m very ambitious. Skil saw might be an option…
Don W
#11 posted 02-22-2014 10:38 PM
I doubt a 7” piece will be dry even in Nevada. I don’t want to start another “how long does it take to dry lumber” war, but an average is about an inch per year.
For about $30 you can pick up a moisture meter and be sure.
