Sharpening Systems
Forum topic by alm265 posted 329 days ago 391 views 2 times favorited 18 replies Add to Favorites Watch
View alm265's profile
alm265
2 posts in 567 days
329 days ago
Topic tags/keywords: sharpen tools gouges irons system
I was wondering if anyone had recommendations on the best setup to use for all around sharpening of most things in my shop (eg. chisels, turning tools, plane irons, etc.)? I’ve used different stones with a variety of lubricants but am trying to figure out the best have trouble with getting bevels consistent and it can be very time consuming. Any suggestions?
View 3fingerpat's profile
3fingerpat
913 posts in 566 days
329 days ago
I started out with a Tormek, which will work for any sharpening task. But switched over to waterstones once I bought better chisels and planes. I didn’t care for the hollow grind that the Tormek left on the cutting surface. I no longer use the Tormek but keep it around just in case I get a lathe and need to sharpen any turning tools. I use both a cheapy honing guide and the Veritas Mk II honing guide system, both work well. I also have trouble getting a consistent bevel edge on my old Stanely planes due to the thinness of the blade, but with time and not as much pressure on the blade while honing, I can usually get acceptable results.
View trimmer's profile
trimmer
29 posts in 339 days
329 days ago
I use the worksharp 3000, best tool i think i ever bought. It’s fun now to sharpen chesels and plane irons.
Not the fastest on dull chesels but to tough up wow!!!!
SCARY SHARP!!!!
View pitchnsplinters's profile
pitchnsplinters
252 posts in 336 days
329 days ago
I’m in the midst of making the same decision. I have studied many options. Tormek is certainly the best, but with a steep price tag. Please post when you make your decision.
Go State!!
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
trimmer
329 days ago
I no u will like the wooksharp3000
It made a believer out of me.
View FlWoodRat's profile
FlWoodRat
586 posts in 807 days
329 days ago
ALM, I went the “frugal” route this morning. I have an old set of Craftsman chisels that have been used for everything but fine wood working for at least 10 yrs. I had a piece of 2.5” x 3” by 15 inch pine and made my own sharpening guide. I beveled one face to 25 Degrees, then dado’d out a 4” wide x 1/8” deep slot , centered on the bottom. I spray adhesived some 3” wide stips of 400, 800 and 1000 grit 3M wet/dry to a piece of granite and started sharpening the chisel I needed to use. In 10 minutes the damn thing was sliciing like crazy on the mortises I drilled out yesterday. Good luck with whatever system you buy
-- I love the smell of sawdust in the morning....
20754 posts in 720 days
329 days ago
I have to add another vote for the Worksharp 3000. Before getting mine I tried stones and sand paper but could not get satisfactory results even with a honing guide. But now I can put a razor edge on the chisels and plane irons.
The biggest drawback to the Worksharp system was that it could only handle irons and chisels up to 2” in width. Anything larger had to be done by hand. But Worksharp has now introduced an upgrade to allow wider irons to be sharpened.
View AjayO's profile
AjayO
4 posts in 369 days
328 days ago
I use dry and wet/dry sandpapers on a 12”x12” Granite tile. I get satisfactory results, but have been looking at Ceramic/Waterstones as sandpapers wear out fairly quickly. I use diamond hone sharpening set to touch up on router bits.
-- - Ajay
View DrDirt's profile
DrDirt
183 posts in 640 days
328 days ago
Though controversial – I have gone the Tage Frid/Marc Adams route and have a 400 grit paper on my 3X21 belt sander then go to a buffing wheel charged with polishing compound.
I have scary sharp in just a few minutes and easy to touch up on the wheel.
For plane irons though I use the wet or dry paper and plate glass route with a veritas honing guide.
By the way love the avatar – PSU 1996 grad Ph.D Chemistry
-- Its never too late to have a happy childhood. But the second one is up to you and no one else.
View Padre's profile
Padre
260 posts in 387 days
328 days ago
I have the Tormek and love it.
-- Chip -- Manchester, Connecticut "When the power of love overcomes the love of power, the world will know peace."
View John Gray's profile
John Gray
1754 posts in 783 days
328 days ago
Worksharp 3000 and Scary Sharp for the wider plane blades, it work’s great.
View marcb's profile
marcb
705 posts in 571 days
328 days ago
I just picked up a set of 3 oil stones. Previously I used scary sharp, but that could be a pain to keep enough supplies laying around.
I highly recommend trying scary sharp and a basic honing guide before going hole hawg into anything. The guide will serve you well in the future no matter what.
View Topapilot's profile
Topapilot
123 posts in 738 days
327 days ago
ALM265,
There is a sharpening method for every woodworker. Unfortunatly, you have to go through all of them until you find yours…
I suggest you save yourself time, money, and frustration, and get a Worksharp 3000. Once your chisels and plane irons are sharp, you can try out all the other methods unitl you find the one that you like better.
Then sell your worksharp for the price you paid, and one week later go buy a new one!
View jeffthewoodwacker's profile
jeffthewoodwacker
487 posts in 702 days
327 days ago
If you do any turning get a grinder with a slow speed setting (eight inch wheels) and upgrade to Norton white wheels. Add a sharpening jig and you have a good system. In addition to picking a sharpening system find someone who knows how to sharpen and learn how to sharpen properly.
-- Those that say it can't be done should not interrupt those who are doing it.
View 8iowa's profile
8iowa
592 posts in 659 days
327 days ago
Last year I took Jim Dillon’s class on sharpening at Highland Woodworking in Atlanta. Jim explained that the wet/dry paper on a flat surface was the most economical method to get into sharpening – but more expensive than wet stones in the long run. I tried the Tormek on plane irons but didn’t care for the “hollow ground” surface. I now have a set of water stones up to #8000 and a Veritas MKII honing guide. The results: I can shave hair and slice paper.
View hokieman's profile
hokieman
50 posts in 652 days
327 days ago
Started out with waterstones and they do an ok job but I feel like I spend as much time flattening the stones as I do sharpening. I also have a granite countertop piece that I do scary sharp on and get good results. I am eyeing the Worksharp as I hear nothing but good about it.
alm265
2 posts in 567 days
327 days ago
I appreciate all the feedback. I’ve been doing a lot of reading and I think I’m going with a worksharp for my chisels and plane irons and some new wheels for my grinder with a jig for turning tools. I’ll let everyone know how it works out. Thanks.
Dave Nesting – always nice to meet fellow grads. 1999 MBA.
Craftsman on the lake
818 posts in 335 days
327 days ago
worksharp 3000. I recently posted a little review and link to a video.
http://lumberjocks.com/reviews/562
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View Kerry's profile
Kerry
131 posts in 688 days
327 days ago
Another vote for Worksharp 3000. I just got one for Christmas and I’m totally impressed. I won’t miss the mess associated with my waterstones, and I can get a terrific edge in a matter of a few minutes. Great system.
Kerry
-- Alberta, Canada
