Sleeves for Ryobi OSS450 drum sander
Forum topic by Charlie75 posted 02-21-2014 04:37 PM 6620 views 1 time favorited 5 replies Add to Favorites Watch
View Charlie75's profile
Charlie75
312 posts in 2498 days
02-21-2014 04:37 PM
I found a Ryobi oscillatting spindle sander that a neighbor had and let me have it for cheap. It has 4 1/2” spindles. I am missing one or two of the rubber spindles and in need of some sanding sleeves. I have a 1”, a 2” and a 3” that came with the machine. I think there are some in between sizes that I don’t have. I was hoping the some one could point me to a source for the sleeves and drums. I will be using these for the BS boxes I am working on.
Charlie
-- Charlie75, Alto
5 replies so far
View syenefarmer's profile
syenefarmer
517 posts in 3314 days
#1 posted 02-21-2014 07:20 PM
Here is one source for both the sleeves and the spindles….http://www.industrialabrasives.com/
Click on Sanding Sleeves.
View woodchuckerNJ's profile
woodchuckerNJ
1305 posts in 1868 days
#2 posted 02-21-2014 07:28 PM
Just try Ryobi, they may have parts,
Also check out HF, for parts if Ryobi doesn’t stock them, the HF unit is the same unit. see if you can order parts from them.
-- Jeff NJ
runswithscissors
2916 posts in 2259 days
#3 posted 02-22-2014 08:53 AM
The Rigid spindle/belt sander spindles work fine on the Ryobi. Identical as far as I can tell.
View maxxh's profile
maxxh
1 post in 633 days
#4 posted 04-22-2017 11:44 PM
I just did something similar recently and found the items I needed for RYBOI 450 at URL
https://www.amazon.com/POWERTEC-Oscillating-Sander-Rubber-Drum/dp/B009NBBAKG
Max
View Hdoilcan's profile
Hdoilcan
8 posts in 633 days
#5 posted 04-23-2017 03:16 AM
I had lost a couple rubber spindles also for the same machine. Grizzly sells the same machine but in a different color. If you go to their website and find it you can look in the parts manual and order what you need. I purchased all new ones (I think 5 in the set) for like $15.00.
