Workbench Top
Forum topic by Notw posted 02-21-2014 01:49 PM 890 views 0 times favorited 3 replies Add to Favorites Watch
View Notw's profile (online now)
Notw
641 posts in 1749 days
02-21-2014 01:49 PM
So I am now back to being indecisive again. I was all set on the idea of using MDF for the top because it would be strong and flat and at a reasonably low price. I was going to use a layer of 3/4” plywood and (2) layers of 3/4” MDF glued and screwed together with a hardwood banding around it. However, now I am thinking I may use a kiln dried 2×10×144 kiln dried SYP board and rip it down to 2-3/4×1-1/2×60” and laminate them together for the top, with this method I should be able to get a 24” x 60” top out of 3 boards. My question is without a jointer or a planer am I going to be able to get a nice smooth flat top? I have no worries about my table saw ripping the boards down and I assume I could always get the top close to flat and then make a router jig to get it even flatter. Just can’t decide which route to take. I would appreciate any suggestions or experience.
3 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2366 days
#1 posted 02-21-2014 02:27 PM
If you have a router and can make a sled, I’d be less concerned with getting the top flat than I would be at getting a good glue-up without a jointer or planer. If the boards are bowed or cupped, it’ll be stressing the joints I would think. I’ve read that others have installed threaded rods through the top to help with that stress, and it sounds like a good idea. But, I’ve never done it, so take that for what its worth. Good luck.
View Tedstor's profile
Tedstor
1643 posts in 2629 days
#2 posted 02-21-2014 02:30 PM
got a hand plane? Assuming your glue-up goes well, a hand plane could probably flatten the top in less time than it’d take to rig-up a router jig.
View schuft's profile
schuft
123 posts in 2603 days
#3 posted 02-21-2014 02:45 PM
To me, the only real reason for a solid wood top is if you plan to use it for hand tools: planing, cutting mortises and tenons, chiseling dovetails, etc. If you plan to mostly use power tools, I’d stick with a simple plywood or MDF top.
Remember that a workbench top is always easily replaceable. So even if you are planning to do more with hand tools in the future, it won’t be a big deal to start with a plywood top and replace it later with something more solid. In fact, you may find that having the plywood top makes it easier to create the solid top.
