Bandsaw Box Glueing
Forum topic by Estey posted 02-20-2014 04:52 PM 997 views 0 times favorited 6 replies Add to Favorites Watch
View Estey's profile
Estey
15 posts in 1577 days
02-20-2014 04:52 PM
Topic tags/keywords: bandsaw box glueing drawer
Hi all, first time poster long time lurcher.
I have a question for those who like to make bandsaw boxes. On the procedures of slicing off the back of the blank and the fronts and backs of the drawers. When it is time to glue them back on…do most of you simply line them up and glue them back on OR do you sand them to flatten the mating faces first?
I have been using the latter method as my intent is to make those lines a invisible as possible but find sometimes I create some problems for myself in terms of being off plane and having to do some recovery work.
Any tips?
Thanks
View Elizabeth's profile
Elizabeth
817 posts in 3106 days
#1 posted 02-20-2014 05:29 PM
I just line them up and glue them back on. If your bandsaw is not producing a clean enough cut to be able to do this, you may not have enough tension on it or be using the wrong blade for the size of cut you’re trying to do.
View wncguy's profile
wncguy
385 posts in 2275 days
#2 posted 02-20-2014 06:48 PM
I do the same as Elizabeth. Early on I did sand first & found that if I had wavered at all in my original cut, sanding created a nightmare getting a “match” back.
If I have a shallow box depth I might hand sand the back only in the areas where it’s not glued so it will be a nice finish for those few that desire to feel the inside back of the box.
-- Any man can be a father, but it takes someone special to be a Dad
View Charlie75's profile
Charlie75
312 posts in 2227 days
#3 posted 02-21-2014 12:24 AM
I, too, just glue them back on.
-- Charlie75, Alto
View gfadvm's profile
gfadvm
14940 posts in 2653 days
#4 posted 02-21-2014 01:34 AM
No sanding here either.
View bondogaposis's profile
bondogaposis
4680 posts in 2314 days
#5 posted 02-21-2014 01:53 AM
Just glue them as is, you’re making more work for yourself.
-- Bondo Gaposis
Estey
#6 posted 02-21-2014 10:35 PM
Thanks everyone. Bondo was right…... more work than I need to do.
Elizabeth, I use a 3/16 10 TPI blade which should be fine as long as I don’t rush it.
I prefer to flock the drawers but I plan to make some out of aromatic cedar so those I will just finish.
I appreciate all the advise
