prevent mitered return from opening?
Forum topic by jtm posted 02-20-2014 08:05 AM 3522 views 1 time favorited 28 replies Add to Favorites Watch
View jtm's profile
jtm
223 posts in 1512 days
02-20-2014 08:05 AM
Hi all,
I’m putting mitered returns on my stair treads, and just want to check whether or not glue is sufficient to prevent the miters from opening due to changes in humidity.
Here is an example of what I plan on making:
Thanks in advance
28 replies so far
View Tony_S's profile
Tony_S
802 posts in 2959 days
#1 posted 02-20-2014 11:20 AM
As long as the tread is an average size and has the proper moisture content(6-8%) it shouldn’t be a problem with any of the domestic hardwoods. I’ve done thousands of them that way…no issues.
If your using Bamboo(pictured above), I can’t say specifically. We’ve built 3 or 4 stairs out of Bamboo in the past, but none had mitered returns.
If anything though, it seemed much more stable than wood.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View basswood's profile
basswood
261 posts in 1496 days
#2 posted 02-20-2014 01:56 PM
Compared to the size of most miters in a home (door and window casing, crown etc.) those are rather small miters. This fact alone bodes well for them staying tight.
Good moisture meters are rather inexpensive these days and checking to see that your stock is nice and dry is good advice:
http://www.amazon.com/Sonin-50270-Digital-Moisture-Meter/dp/B005GHLGGE/ref=pd_sbs_hi_6?ie=UTF8&refRID=0C0RQBTDCCBZDX26J5WT
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
View Rick's profile
Rick
8605 posts in 2908 days
#3 posted 02-22-2014 06:55 AM
You might want to try a couple of these. (Below)
I just did an Outdoor Table for a Friend and used them even though the corners are held together with 2, 2-1/2” Deck Screws and Plugged.
Only problem is I have No Idea what they are called or where you can get them …LOL… I’ve had a bunch of them sitting in a Plastic Drawer in My “Hardware Pull Out Drawer Case” for Years now.
Personally? I think they Work & Hold Very Well!
-- A Chip On The Shoulder Usually Indicates Wood Higher Up. (Rick, Ontario, Canada)
View NoLongerHere's profile
NoLongerHere
893 posts in 2552 days
#4 posted 02-22-2014 12:45 PM
Hey Tony, do you route the joint like this?
I have a jig that 45s the joint….if even needed. Not sure I like this look.
I imagine it would be a faster one step process with a flush bit VS cleaning up a 45.
Maybe if it didn’t sweep so much and just had a rounded inside corner?
JTM – curious, what will the hand rails be made from? do they make bamboo hand rails? will you be staining it? have you considered having just end grain and no return?
Rick – I’d be real surprised if you could hammer that into bamboo or any hardwood for that matter. You’d probably be better off with a biscuit or M&T or glue and nail or screw and cap.
I like your avatar….you’re like the Grizzly Adams of LJ.
View Rick's profile
Rick
#5 posted 02-22-2014 11:06 PM
Be Surprised then. These things are VERY Hard. I’ve used them in Oak & Walnut so far.
”Glue And Nail”? ”Just end grain and NO Return?” ”Maybe if it didn’t sweep so much and just had a rounded inside corner?”
HUH???
Tony_S
#6 posted 02-23-2014 12:44 AM
Mark
I agree 100% with you on the large radius, it looks like shit. A 3/8” diameter leaves a barely noticeable round in the corner though. The only time I use a true (two piece)miter is for a convex tread(whether it’s a straight or curved stair) because the nosing is typically a bent lamination glued separately and then glued to the tread with the return.
No mechanical fasteners of any sort are needed especially the ones pictured above. A good clean joint, Tightbond and clamps is all you need…even if you could pound those in without breaking the joint they would be pretty unsightly on a staircase.
NoLongerHere
#7 posted 02-23-2014 12:47 AM
Are they pre-making treads like this now? always something new.
View Rick's profile
Rick
#8 posted 02-23-2014 02:39 AM
“No mechanical fasteners of any sort are needed especially the ones pictured above. A good clean joint, Tightbond and clamps is all you need…even if you could pound those in without breaking the joint they would be pretty unsightly on a staircase.
The “Ones Pictured Above” are on the UNDERSIDE of the Table Joint. No one can see them. That’s where I was suggesting they be put on the Tread. Would that not be Possible? Would they still be seen?
Personally I don’t give a Rats Butt how he does it. I was just offering a suggestion. Of course you being the High ZEN Mucky Muck of Stairs & Tread Technology, I would think that he would take your Advice over mine.
Nice Blogs though ”.I just thought since I tend to get a bit ‘opinionated’ on certain subjects….here and there…(translates into ‘piss people off’ sometimes)
Happy Now MR. Tony??
View jtm's profile
jtm
#9 posted 02-23-2014 07:42 AM
Thanks for the responses.
The treads are cherry.
And these miters have turned into a royal pain in the ass.
View jtm's profile
jtm
#10 posted 02-23-2014 08:29 AM
So I made a jig to cut the miter on the tread.
I had to make it upright to account for the radius of the blade. Otherwise, I would have over-cut into the bottom side of the tread.
Then I use the SCMS to crosscut up to the mitered 45. After that, I finish the cut by hand.
The problem is, when I complete the cut by hand, I can’t keep the cut perfectly smooth and square like my table saw.
Here are some pics:
I glued one up and there is a tiny gap at the joint. It’s not the end of the world, but I’d like to make the rest better if possible. I’m open to suggestions.
Also, I’m thinking about using pocket screws to hold the return in place. It’ll also make clamping these returns much easier during glue-up. Any reason not to do so?
Tony_S
#11 posted 02-23-2014 10:37 AM
The simplest way for you to execute this would be to do as Mark suggested above and make a jig and use a flush trim bit(3/8”Dia. works well).
Mark your return lines on the tread and cut the excess out on a bandsaw about 1/16 away from your pencil line leaving a little bit more material in the crotch of the miter. Clamp the jig to the top of the tread, turn it over and trim the joint clean with the router.
The heel of the miter on the return will need a small round to fit the tread. You can do that with a jig or by hand.
To glue, I would use a hand clamp as you’ve done above and two pipe clamps across the tread.
The other option would be to miter the front nosing separately and then glue it on.
The screws really aren’t necessary for what you’re trying to achieve, but if your more comfortable with that, give it a try.
My main concern with the screws would be 1. It shouldn’t be necessary 2.The time it would take to do it accurately. 3. Hitting a screw when you’re bullnosing the edge or 4. having a screw hole show even if you did remove the screw before profiling.
Not a whole lot of room for error there.
You never know though….if you can get the screws positioned perfectly you may not even need the clamps.
The high zen mucky muck of stair and tread technology.
PS.
Mark, yes pre-made stock treads with returns are readily available but only in limited dimensions and materials.
Quality is often an issue as well.
View Rick's profile
Rick
#12 posted 02-23-2014 10:49 PM
EDIT: Removed.
View jtm's profile
jtm
#13 posted 02-23-2014 10:50 PM
I don’t have a 3/8” pattern bit, but I do have a guide bearing set.
And I don’t have a bandsaw or jigsaw either. (Although I’m in the market for one – can’t decide on the Laguna 1412, Rikon 10-325, or a 17” Grizzly, but that’s for another day)
View jtm's profile
jtm
#14 posted 02-23-2014 11:08 PM
Well this sucks…
What the hell good are those guide bearing kits if they obscure 80% of the available cutting area on the router bit?!?
I have a 1/2” pattern bit. I’ll use that, and while I hate the look of full radiused miters (like the pic in the first post), I can live with the slight radius caused by the 1/2” bit.
Tony_S
#15 posted 02-23-2014 11:09 PM
Sounds like the easiest way for you to get through this would be mitering the nosing and return separately from the tread, then gluing them on. It’s a bit slower than the method I described previously, but will be a lot quicker than what your struggling with now.
The end results will be better as well.
showing 1 through 15 of 28 replies
