How would you shopize this Ikea saw horse?
Forum topic by Lee Barker posted 02-19-2014 10:15 PM 5454 views 0 times favorited 18 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 3091 days
02-19-2014 10:15 PM
Assume you were given a pair of these.
They are lightweight, compact dimension, and could be hung up or stored fairly simply and be very handy in finishing or staging project parts, say.
However, this joinery would never hold up in a shop. I’m just curious what you’d want to reinforce and exactly how you’d go about it.
Let’s say that we don’t want to alter height or splay or the length of the top member, and we’d like easily to be able to hang them up without using a stool.
Ready? Go!
Kindly,
18 replies so far
View bigblockyeti's profile
bigblockyeti
5319 posts in 1961 days
#1 posted 02-19-2014 10:20 PM
I think I’d take them apart and epoxy everything together before tightening down. Another thought if you just wanted to set them in the corner would be to move the center stretcher to one pair of legs and add another on the opposite side. Then you could cut down the top of the other so they could nest together, halving the floor space two of them would take up.
View TheDane's profile
TheDane
5576 posts in 3904 days
#2 posted 02-19-2014 10:31 PM
I like the “Key features” ... they only list one: “Solid wood is a durable natural material.”
I think I would look for an opportunity to ‘re-gift’ them.
View Terry Ferguson's profile
Terry Ferguson
203 posts in 2908 days
#3 posted 02-19-2014 10:47 PM
I’m with the Dane on this one and build some simple folding ones.
If that doesn’t fly for you, use a ceiling mounted pulley, a cleat, and some rope(s) pull them up out of the way.
Just my $0.02 worth.
-- Terry Ferguson, Bend Oregon
View greg48's profile
greg48
610 posts in 2998 days
#4 posted 02-19-2014 10:59 PM
If you wished to hang them up somewhere out of the way, it would be nice if they folded up. I don’t see that happening with this design. However, let me show you what I found some time ago at a large orange box store. I bought one and duplicated the design using 2×4 and 1×4 lumber (dry).
They measure 29” wide and stand 27” tall. Two butt hinges, a length of light weight chain to keep the legs from splaying, and some 1 1/4” #8 FH screws is all the hardware used. As you can see, they fold up (4 beneath the wing of my saw) and are mostly out of the way.
That’s my 2 bits and worth all of that.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View DrDirt's profile
DrDirt
4526 posts in 3983 days
#5 posted 02-19-2014 11:13 PM
I think the would be prett strong for holding projects -
I would change the attachment of the stretcher.
I assume it is just a wood screw, or perhaps a threaded insert in the stretcher – with one screw throuht the leg.
To strengthen it – I would change to these – so the can pull tight and be better anchored in the leg.
Then I would have two screws at the top of each leg, to make it less likely to rack
View higtron's profile
higtron
247 posts in 2918 days
#6 posted 02-19-2014 11:18 PM
I would build a set of horses myself, it always cracks me up when woodworkers buy horses. I’m a union carpenter have been one for a lot of years, apprentices make a set of horses as their first project when they go to school. Horses that you buy are never as solid and, sturdy as a properly constructed pair if you are looking for some low profile horses that don’t take up much shop space build a set of sturdy knock down horses out of a sheet of 3/4” plywood
-- A friend will help you move, a good friend will help you move a body
View MrRon's profile
MrRon
5277 posts in 3484 days
#7 posted 02-20-2014 04:55 PM
I made my saw horses with a wide top platform. The legs splay in two directions for a very stable platform. A pair of these will support an enormous weight.
The Ikea horses were not designed to be used as saw horses, but as legs for a temporary table. They are not suitable for shop use. For the amount of modification needed, you would be better off building from scratch.
117420 posts in 3818 days
#8 posted 02-20-2014 05:29 PM
These look like a pretty simple design Lee
View Richard's profile
Richard
1922 posts in 2931 days
#9 posted 02-20-2014 05:47 PM
I would explain to the person who gave them to me why to not buy any wood items from Ikea and then give to someone else of put them in the Fireplace.
View basswood's profile
basswood
261 posts in 1861 days
#10 posted 02-20-2014 06:52 PM
I am all for building your own. Not necessarily according to anyone’s plans exactly.
Look at what is out there and the plans and ideas posted here already, and customize them for your purposes. These are the horses I designed and built this past year. Sturdy enough for serious shop work and they knock down flat. Here is the LJ project post about them: http://lumberjocks.com/projects/96307
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
View jimintx's profile
jimintx
864 posts in 1825 days
#11 posted 02-20-2014 08:38 PM
Lee, you asked what to do with the ones you showed us. When checking them out at the link you provided, these items are not sawhorses, and are not represented to be. They are marketed as a set of table legs. On the Ikea site, after you go to the link you gave us, you can find the whole table set up here
http://www.ikea.com/us/en/catalog/products/S89002010/
I think the answer is to make a lightweight table – a little desk, for example. As others have said, work on more useful sawhorses as a separate project. You could make sketches of the saw horses while sitting at the little Ikea-based table.
-- Jim, Houston, TX
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3826 days
#12 posted 02-20-2014 08:48 PM
I have never used or seen the ikea ones in the flesh, so to speak .However from what I can see here, from the pics they lok a little bit flimsy sorry just my observations. Which as you know is generally not a quality desirable in sawhorses.
I suppose you could beef them up a bit but.I would in that case rather just go ahead and make my own, or buy a decent set of metal ones. MY 2.25 cents LOL .Alistair have safe fun.
View moke's profile
moke
1283 posts in 3017 days
#13 posted 02-21-2014 01:57 PM
I’m with Gerry—”theDane” I’d look for an opportunity to make them someone else’s problem/project!!!
Mike
-- Mike
View Magnum's profile
Magnum
10935 posts in 3274 days
#14 posted 02-22-2014 06:30 AM
As already pointed out these are NOT Intended to be Saw Horses. They are Table Legs and are Labeled as such.
They are intended to be used for one of many tops. This top (with those Legs Sold Separately) sells for $65.99.
-- Made In Ontario, CANADA
View TravisH's profile
TravisH
642 posts in 2176 days
#15 posted 02-22-2014 02:54 PM
Hmm tricky question as most didn’t even try to answer the actual question. I am disappointed however because the thread has gone way to long without the usual… buy used on craigslist catch all answer.
Lee I wouldn’t do anything with them, use them as is and wait to see when they need fixing. If you are just using them for “table legs” for a finishing table or similar might last as long as you want them to as is.
