Question about full extension drawer slides...
Forum topic by pashley posted 02-19-2014 06:43 PM 1953 views 0 times favorited 30 replies Add to Favorites Watch
View pashley's profile
pashley
1043 posts in 3687 days
02-19-2014 06:43 PM
Okay, so the customer wants “full extension drawer slides”, which, as I understand it, allows the drawer to be pulled out so that the back of the drawer (at least) meets, or goes beyond the face frame.
The drawer length, from the back of the false front to the back of the back is 28”.
I know this sounds stupid, but do I buy 28” full extension drawer slides? Can you get away with smaller ones, say, 26”, and still get the “full extension” effect?
-- Have a blessed day! http://newmissionworkshop.com
30 replies so far
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1697 days
#1 posted 02-19-2014 06:52 PM
You can buy guides that have a 1” over travel.
Example: 26” guide will pull out 27”. But that’s it as far as I know.
I think you need to get the 28” size.
View pmayer's profile
pmayer
1026 posts in 3035 days
#2 posted 02-19-2014 06:56 PM
You can use them but you will be a couple inches shy of full extension. Might be good enough, or might not, depending on what your customer really needs. If your goal is to get a full extension effect with a shorter slide mechanism, you can use “over-travel” slides. I am using these on a project now where there is going to be a sizable overhang above the drawer, so I need the additional extension.
View Clint Searl's profile
Clint Searl
1533 posts in 2331 days
#3 posted 02-19-2014 07:02 PM
You need the 28” to fully expose the drawers.
View DrDirt's profile
DrDirt
4423 posts in 3712 days
#4 posted 02-19-2014 07:39 PM
Indeed you need the 28” slides – unfortunately slides that long are uncommon – as they tend not to be for residential use (tops out generaly at 24”)
So it is hard to find e.g. Blumotion or Hettich undermount slides with soft close that are that long.
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2339 days
#5 posted 02-19-2014 07:45 PM
You could probably do the 26” slides if the drawer box is only built 26” deep. It would appear to be a full extension drawer. Unless the customer got out a measuring tape, and asked where the other 2” of drawer space went to.
View MT_Stringer's profile
MT_Stringer
3160 posts in 3201 days
#6 posted 02-19-2014 07:54 PM
I wouldn’t do it. In my opinion, you might not have enough clearance for those unexpected events. It seems to me 26 or 27 inchers would be fine. Heck, make your drawer a little shorter. :-) When you install it and pull it out, it will appear to be full extension. Just my opinion.
Edit: “You could probably do the 26” slides if the drawer box is only built 26” deep. It would appear to be a full extension drawer. Unless the customer got out a measuring tape, and asked where the other 2” of drawer space went to.”
Yeah, that is what I was trying to say. :-)
Good luck with whatevr decision you make.
Mike
BinghamtonEd
#7 posted 02-19-2014 08:04 PM
Honestly, if they were my cabinets, I wouldn’t mind having 1-2” of the drawer still inside the cabinet when fully opened. Makes it that much harder for me to accidentally drop something down in behind the drawer..
View gamygeezer's profile
gamygeezer
166 posts in 1555 days
#8 posted 02-19-2014 08:51 PM
Amazon.com lists several 28 inch slides, some with overtravel.
-- What's a vibrant young guy like me doing in a broken down old body like this?
View pintodeluxe's profile
pintodeluxe
5626 posts in 2783 days
#9 posted 02-19-2014 09:00 PM
Full extension slides, even slightly shorter than the cabinet depth, will still be much better than “3/4” extension slides.
View Lee Barker's profile
Lee Barker
2170 posts in 2820 days
#10 posted 02-19-2014 10:00 PM
Since we’re down to inches (and worrying about same) note that a 20” slide is actually a little less than that—probably millimetric, now that I think about it. So a 28” slide, according to my theory, would be 70 mm or about 27 9/16.
Drawers generally are 2” less, front to back, than the carcase dimension.
Kindly,
View Rick's profile
Rick
9439 posts in 3003 days
#11 posted 02-20-2014 03:24 AM
Lee Valley has 2 Pages of Drawer Slides HERE
The ones below are from there. They are Both Full Extension, up to 28”. (26”, also if that’s what you decide)
First One is a Standard Kitchen Slide at 75Lb Capacity.
Next one is a Self Closing Model.
-- LIFE is what happens when you're planning on doing Other Things!
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2042 days
#12 posted 02-20-2014 09:53 PM
To add to this thread and answer your original question directly, in my mind full extension means full extension, and I would provide the customer with that. That would mean a 28” full extension guide on a 28” deep box. (note most undermount guides are sold in 3” separations, eg> 9”,12”,15”,18”,21”,24”,27”,30” where as side mounts in 2”)
-- Who is John Galt?
View Rick's profile
Rick
#13 posted 02-21-2014 11:30 PM
You still here Pashley?
View bigblockyeti's profile
bigblockyeti
5106 posts in 1690 days
#14 posted 02-21-2014 11:35 PM
I had to get the exact dimension for my dresser drawers. Stay away from BORG if you’re looking for quality, the ones I got were ok initial, soon after turned to junk.
pashley
#15 posted 02-22-2014 02:21 AM
I’m here….got 26” fulls….I’ll see how it goes….
showing 1 through 15 of 30 replies
