Rabbets in thin workpiece?
Forum topic by elm posted 02-19-2014 05:49 PM 908 views 0 times favorited 4 replies Add to Favorites Watch
View elm's profile
elm
16 posts in 1652 days
02-19-2014 05:49 PM
Topic tags/keywords: oak grain oak stack dado tear out small workpieces back routing rabbet stack dado set grain
Suggestions please.
I am trying to mass produce several dozen trivets that measure 8 1/2” square. Frame is made from 3/4” square red oak strips. Inside this frame is 7” square filled with wine corks. Bottom is 1/4” hardboard glued into 3/8” x 1/4” rabbet cut in frame. A 1/4” round over bead is around outside edge.
On first few I assembled frame. Then routed rabbet and decorative round over bead on router table. Oak grain is such that there is lost of tear out. Tried back routing in places. Had minimal success. Don’t like the back routing thing anyway.
Thought I would try cutting rabbet in oak strips on table saw with stack dado set. Then miter corners and glue up frame. Problem is how to cut rabbet safely on such small workpieces.
Any ideas, please?
Thanks
Ed
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2244 days
#1 posted 02-19-2014 06:16 PM
I would take a length of the 3/4×3/4 red oak and rabbet it on the router table using featherboards to keep it against the table and fence. If I were mass producing it, I would make a miter jig for a small handsaw that was basically a block of wood that had a 3/4” groove in it, along with a kerf at 45 deg to the groove. Take the strip with the rabbet, put it in your miter jig, make the cut. Move the piece, repeat. You could add a stop block to the miter jig and whip these things out fast.
Edit : If you’re getting a lot of tearout on the router table, you may be taking off too much in one pass. I assume the grain runs along the 3/4” strip and not perpendicular to it. You could also score the rabbet before cutting it to help cut down on the tearout.
View Redoak49's profile
Redoak49
3015 posts in 1863 days
#2 posted 02-19-2014 11:19 PM
For round over router bits, I have found the Freud Quadra Cut ones have the least amount of tear out on oak. There is a lot of difference in router bits and how well they perform for tear out.
The suggestion to take smaller cuts is a great one.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1946 days
#3 posted 02-19-2014 11:23 PM
+1 post 1 I would do in router table. If TS is your option, mill the peices wide, run the dado on two sides of a wider board, then resaw in half or down to the size needed, to make safer. I do this often when milling profile that will be smaller.
-- Who is John Galt?
View bondogaposis's profile
bondogaposis
4529 posts in 2225 days
#4 posted 02-19-2014 11:24 PM
I would cut the rabbet first on a wide board then rip it to finish width after the rabbet was cut. You could rabbet both sides of the board then rip 2 from each board.
-- Bondo Gaposis
