11 different finishes on Walnut - the initial coat (long but awesome) *UPDATED*
Forum topic by lumberjoe posted 02-18-2014 04:42 AM 14048 views 7 times favorited 39 replies Add to Favorites Watch
View lumberjoe's profile
lumberjoe
2899 posts in 2270 days
02-18-2014 04:42 AM
Topic tags/keywords: finishing shellac blo tung oil arm-r-seal teak oil danish oil waterbased poly
So I decided to “bust some myths” about finishing. Most notably that pure tung oil and boiled linseed oil based finishes pop grain better than anything else. Here is what I used (note Lacquer omitted – can’t spray inside and too cold outside). All the walnut has been sanded to 220 grit
Zinsser Shellac (3lb cut right out of the can, waxed, brushed)
Minwax semi gloss poly (I thin it 50/50 with MS to make a wipe-on)
Pure tung oil
Watco Teak oil
Watco Natural Danish oil
Custom blended finish (“Maloof” finish)
General finishes Arm-R-Seal (Gloss)
Varathane soft touch Matte poly (waterborne)
Varathane Ultimate waterborne poly (oil modified, full gloss)
2lb Cut dewaxed superblonde shellac (brushed)
2lb Cut dewaxed superblonde shellac (french polished)
I generally do this with scraps from pieces I am using for a project. You can see how wildly one species can vary in color
This has been pore filled already – 1lb cut of dewaxed shellac, let it dry, then rub with a french polishing pad – but only alcohol on the pad. The pad is tapped on some pumice periodically to work the dried shellac and walnut into the grain. I didn’t do a terrific job here (It will show later)
The rest of them. Taped off so I can see the natural wood after for a real comparison.
First coats applied
1st padding session. French polish brings out every single little defect (lazy pore filling and planer snipe that wasn’t visible before). This looks like crap compared to the final session and after rubbing out with rottenstone; but getting glossy.
Pure tung on the top, my custom finish based on Sam Maloof’s finish on the bottom – Poly, tung oil, boiled linseed oil, and solvent. My skepticism of boiled linseed oil popping grain better than pure tung oil is fading a bit.
Waterborne “poly” (gloss) vs minwax semi-gloss. Not too much difference yet. I thinned the oil based poly to wipe it so there is barely any there. That side will be much darker
Watco “teak oil” vs Canned Shellac.
Not too much difference here actually. The shellac will be much glossier. I’m not sure what is in “Teak” oil but I actually like it. I use it on razor stands because it is an outdoor finish. My guess is Tung oil and a spar varnish. It doesn’t build a film, but is really glossy for an oil/varnish.
Natural Danish oil vs waterborne Matte Poly. Both “natural” finishes. The matte waterborne acrylic side looks like there is nothing there. By the way, this Varathane soft touch matte poly is AWESOME.
And here is the kick in the nuts I wasn’t expecting. Dewaxed shellac (brushed) vs Arm-r-seal. I always thought shellac (even as a washcoat which is what this basically is) did a terrific job at popping grain. Not even close.
I am going to follow the proper finishing schedule on all of these finishes and rub them out as well. Interested to see the final results
39 replies so far
View Randy_ATX's profile
Randy_ATX
879 posts in 2464 days
#1 posted 02-18-2014 04:52 AM
I’m always interested in these types of comparisons. Will the final results be posted in this thread? I’d like to know what your top 3 choices will be once you are done.
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
TheWoodenOyster
1317 posts in 1957 days
#2 posted 02-18-2014 05:08 AM
Cool. I am about to do some table legs in walnut and was going to do straight BLO. I’ll be interested to see your results. Thanks for taking the time to share this with us all.
-- The Wood Is Your Oyster
lumberjoe
#3 posted 02-18-2014 05:45 AM
I would never use BLOCK (or straight tung oil) as a finish. Maybe try a danish oil.
View Handtooler's profile
Handtooler
1574 posts in 2154 days
#4 posted 02-18-2014 12:19 PM
Yes, Absolutely show us more. Neither Flexnor nor Charles has done such a very nice comparison that I’ve seen. Useful knowledge.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Kaleb the Swede's profile
Kaleb the Swede
1835 posts in 1991 days
#5 posted 02-18-2014 12:24 PM
Thanks for this lumberjoe. This is really eye opening to different finishes and to somebody who knows nothing about them, a great help
-- Just trying to build something beautiful
View mahdee's profile
mahdee
3888 posts in 1790 days
#6 posted 02-18-2014 12:38 PM
Thanks Joe, Like to see how they turn out. I have come to like Teak oil because it is so easy to wok with.
-- earthartandfoods.com
View SpartyOn's profile
SpartyOn
28 posts in 2169 days
#7 posted 02-18-2014 01:41 PM
Thanks for taking the time to do these comparisons, Joe. Very helpful. Looking forwad to the final results!
View CharlesNeil's profile (online now)
CharlesNeil
2410 posts in 3893 days
#8 posted 02-18-2014 01:43 PM
We actually did a ton of this stuff , all sorts of finishes, unfortunately it was for our book .
View Clint Searl's profile
Clint Searl
1533 posts in 2383 days
#9 posted 02-18-2014 02:07 PM
The experiment is cute, but won’t prove anything. The simple fact is that anything that “wets” the wood will emphasize the grain pattern. Claims of differences between various concoctions due to reflectance, refraction, or some other optical phenomenon are meaningless gobbledygook. Any observed differences are 99.9% due to a change in color carried by the finish.
lumberjoe
#10 posted 02-18-2014 02:58 PM
Clint, go read some finishing books and troll another thread please
lumberjoe
#11 posted 02-18-2014 03:00 PM
Charles, your book is awesome. I would highly recommend it to anyone
View moke's profile
moke
1179 posts in 2798 days
#12 posted 02-18-2014 06:42 PM
Joe, even in the magazines they make their recommendations…top tool…etc…
Which one do you now prefer? The Arm-r-seal looks awesome from my perspective….what say you?
Mike
BTW—-thanks for all your efforts….good post
-- Mike
View CharlesA's profile
CharlesA
3329 posts in 1820 days
#13 posted 02-18-2014 07:14 PM
Clint,
I agree that there is some gobbledygook on this thread, but I I find it in your almost indecipherable post. If someone takes wood and uses different finishes with observed differences, how is that meaningless? Do some finishes “wet” the wood more deeply and with longer lasting results? Popping the grain is not always mymgoal in finishing, but this is still interesting.
Charles
lumberjoe
#14 posted 02-18-2014 07:48 PM
My goal when finishing first is protection. Some of these finishes would never even be considered for furniture. This is very un-scientific and I just want to experiment with looks alone.
There are a lot of perceptions about popping grain, appearance, etc. I want some empirical evidence so I know what I am dealing with down the road
View ex-member's profile
ex-member
186 posts in 1797 days
#15 posted 02-18-2014 08:47 PM
There’s one in every thread. I’ve been that one, so I know. Clint, every piece of wood will take a finish differently than the next. This is highlighting some very impressive differences, in general, about how these finishes affect one species and none of them could be considered stains so just chill. This is interesting. Now play nice or go to another thread.
I, for one, can’t wait to see the finished pics…and maybe a month of aging as well.
showing 1 through 15 of 39 replies
