Best wood for trivet
Forum topic by sfwoodnovice posted 02-17-2014 06:56 PM 1571 views 1 time favorited 6 replies Add to Favorites Watch
View sfwoodnovice's profile
sfwoodnovice
2 posts in 1466 days
02-17-2014 06:56 PM
Topic tags/keywords: trivet type of wood
Hello folks,
I’m wondering if you can help me out. I have an idea to make a nicely designed, almost an artistic, trivet out of wood. Does anyone have a recommendation for the type of wood I should use and if I need a certain type of finish? I am a complete novice so forgive me if this is an elementary question as I know not.
Thanks
View basswood's profile
basswood
261 posts in 1527 days
#1 posted 02-17-2014 06:57 PM
I’ve heard Ipe can take the heat… but it can be another matter to get it to take a finish.
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
View MisterBill's profile
MisterBill
411 posts in 2158 days
#2 posted 02-17-2014 07:13 PM
The idea of a trivet is supposed to be that you put something hot on it instead of on your countertop. In other words, it is a sacrificial object. Use whatever you have on hand and don’t look back.
sfwoodnovice
#3 posted 02-17-2014 07:17 PM
Basswood,
Thanks for the input. I’ll research ipe wood and see if it’s feasible.
MisterBill,
Yes, there is a sacrifice component to a trivet but I would like to find a material that won’t burn or tarnish. There has to be some sort of wood that can withstand contact with a hot object without burning or leaving a last mark, right?
Thanks
MisterBill
#4 posted 02-17-2014 10:36 PM
SF,
Try to use the darkest and hardest/densest wood that you can find. Brazilian Cherry isn’t the darkest but it definitely hard and dense.
View Net55's profile
Net55
78 posts in 1494 days
#5 posted 02-17-2014 10:44 PM
Oil based finishes hold up better to heat. All wood will burn, go with dark hard wood when in doubt. I did some a few years ago out of tiete rosewood, not a mark on them.
-- Bill, SW Florida
View Ingjr's profile
Ingjr
144 posts in 2923 days
#6 posted 02-19-2014 12:49 AM
I’ve had a couple of walnut trivets I made years ago that look as new. I use MS, Poly, BLO in 1/3 quantities for a finish. As I almost always do.
-- The older I get the faster I was.
