goatskin parchment application (cabinet)
Forum topic by acol posted 02-17-2014 06:28 PM 1034 views 0 times favorited 3 replies Add to Favorites Watch
View acol's profile
acol
6 posts in 1429 days
02-17-2014 06:28 PM
Hi all, this is my first post so hopefully you can be of help.
I’m doing a cabinet making college project i intend to wrap the cabinet in real goatskin parchment. The effect i intend to achieve is a check pattern made out of squares or ‘tiles’ cut from the parchment.
The problem is finding information regarding the application of parchment to (in my case MDF 18mm) ie: weather the parchment can be glued down while dry or does it have to soaked first? And in either case what type of glue should i use. Hige glue? Fish glue?
I’d greatly appreciate help with this matter as its almost impossible to find information regarding this.
Regards Andrew
3 replies so far
View shipwright's profile
shipwright
7847 posts in 2667 days
#1 posted 02-17-2014 06:58 PM
I played around with it last year. See this blog.
I followed instructions from Gene (vipond33) and I don’t recall everything but it has to be wet and you have to use fish glue. I wasn’t using it in the traditional way but it is definitely fun stuff.
If you want me to try to look up the stuff Gene sent me about it, PM me and I’ll have a look.
Good luck.
View acol's profile
acol
#2 posted 02-17-2014 08:43 PM
Thanks for the reply, im new here so cant send pm’s yet. Interesting you metion genes project I just came across it after I posted. If you have any info id much appriciate it as its a pretty specilised area. Thanks
shipwright
#3 posted 02-17-2014 10:51 PM
I PM’d you the info I have.
