| Forum topic by Woodshopfreak | posted 326 days ago | 392 views | 0 times favorited | 13 replies | ![]() |
326 days ago |
Topic tags/keywords: question oak joining Okay, fellow lumberjocks. I have a tough question here. I need to know how to attach the top piece of my “shoe shine box” to the sides of the top piece. The problem is, is that the box joints are running different directions and the top is solid wood. I’m worried that if I glue the top deice to the sides that the box joints will eventually crack apart! I have seen how you can make little wood block things that hold to top on, but I don’t really want the blocks on the inside to be seen. Do you think that gluing the top on will crack such a strong joint such as a box joint? If so please tell me some way to attach these two pieces without running into expansion, and contraction issues. Thanks. -- Tyler, Illinois |
326 days ago |
The only way that I could think of it to only glue in the middle of the top but only 2-3” just in the center of the ends. You could also put some screws in the center of the ends and then use fake plugs in other spots to give it a symetric look. You could put slots on the outer edges that would allow the wood to move on some screws. similiar to the way that breadboard ends are attached. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
326 days ago |
I read this post earlier and came back after thinking about it for a little while. Karson already suggested my ideas though (and one more). The only other thought is that if you haven’t already glued up the sides, you might be able to switche the design over to some type of floating panel design. I can’t tell if you’ve already glued it or not though. |
326 days ago |
I dont think you would have any problems with breaking the box joints. I woud cut a rabbit around the sides of the lid and set the lid in a little, this would give you some more glue surface making it stronger. |
326 days ago |
If you glue the top fully it will crack, and carson has some good suggestions, |
326 days ago |
What about attaching it with dowels or biscuits? You could glue the dowels on the sides going with the grain and leave the ends dry. -- Kate, http://www.wooden-box-maker.com |
326 days ago |
screws. |
326 days ago |
After some more thought, I’ve got an idea, but it would proabbly change the look of your project. This is similar to Karson’s last suggestion. You could drill 4 holes into the edge of the project sides (where the sides will contact the top). These four holes could hold a dowel. then cut 4 short slots wide enough to accomdat the dowel. Slide the top over the dowels and put a cap of some type over the dowel. It could be 2 long strips with two holes in each. It would basically sandwhich the lid between the strips and the side like it is squeezed in a vise. Not sure if I’m conveying the idea well, but hopefully this helps. If not, PM me and I can try to clarify. |
326 days ago |
Come on you guys, in theory yes the top could crack, but the original question was weather it would break apart the box joints. This box is so small that in my opinion it would never break apart the joints. He could drill down through the joints and put a dowell in it to lock the joint together also. I’m not meaning to argue about the top cracking, but I have made several projects of the like and had no problems. I’m only basing my Opinion on my experiences. How big is it? 10×12? I just don’t see it happeneing, sorry |
325 days ago |
I think I’m with bentlyj. The first question is how big is the box? Without any good visual clues in the photos, I’m guessing the box is 6” wide? I did a little reading, and for cope-and-stick joinery and mortise-and-tenon joinery the general rule is that a glued cross-grain joint can safely be up to 6”. I would think that would apply here as well, since this is just another cross-grain joint. Looking around this website at small boxes, a few lids are frame-and-panel, but most of them appear to have the top directly attached to the sides, either trapped within or glued on. I wouldn’t build a 24” wide hope-chest lid this way, but for a small box, I really think you are okay. -- http://www.north40custom.com -- http://north40studios.etsy.com -- |
325 days ago |
the box is about 8 1/2 inches wide and 11 inches long. Thats also what I was thinking. If I can’t glue it I might just counterbore some screws in each of the corners and then get a plug cutter and match the grain of the plug with the top so you won’t see it. When the wood expands I would think it would just flex the 1/32 to 1/16 and not crack at that little movement. I don’t want to put screws in because I don’t want plugs at all in the top. My dad has suggested blocks on the inside that could work but the problem is they would detract from the whole project I think. -- Tyler, Illinois |
325 days ago |
Tyler, I know you don’t want screws, but maybe you can live with this. I got this from FWW mag. for attaching a tabletop. You drill a tapered hole and countersink the small end. Put the big end of the taper against your top board, screw it down and plug the small end. This allows the top to move a little. At least you won’t see the plugs when your box is closed. -- Carl Rast, Pelion, SC |
325 days ago |
Carl, thanks so much, I think that is what I’ll do. And the picture was great. I’ll just get a plug cutter and match the gain on the bottom so that you won’t even see the plug that much. That seems like the easiest, and most effective way of attaching the top. Thank You so much. -- Tyler, Illinois |
325 days ago |
Glad I could help! -- Carl Rast, Pelion, SC |
| Forum | Topics |
Woodworking Skill Share
2904 |
3926 |
256 |
943 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2371 |
LumberJocks.com Site Feedback
522 |
