Are Bench Dogs and Hold Fasts Universal sized?
Forum topic by JohnMcD348 posted 02-17-2014 03:45 AM 1132 views 0 times favorited 3 replies Add to Favorites Watch
View JohnMcD348's profile
JohnMcD348
50 posts in 1590 days
02-17-2014 03:45 AM
Just wondering so I can plan ahead. I’m going to be building a workbench in the coming months and I’m collecting parts and pieces now. I was watching Woodsmith Shop’s episode on Benches today, for the umpteenth time, and the units they were using on their bench used 3/4” holes. Also, the square, flat faced dogs, is there a set size for those also or is it something I would buy and build the bench holes specifically for them?
Thanks
3 replies so far
View lepelerin's profile
lepelerin
495 posts in 2318 days
#1 posted 02-17-2014 04:39 AM
I think bench dog are 3/4” in north america and 20 mm in europe. I have some from France and they are 20 mm (a little bit over 3/4”). My home made are 11/16”, I cannot say what is the standard but they fit perfectly in a 3/4” hole.
View woodchuckerNJ's profile
woodchuckerNJ
1274 posts in 1627 days
#2 posted 02-17-2014 04:55 AM
There’s no standard size in either round or flat. But the veritas dogs are 3/4
I have the gramercy holdfasts… excellent, also 3/4, but I have a woodcraft holdfast for my old bench and it was smaller. if you are going round, then 3/4 would be safe in the USA and Canada, if you are not then I’m not sure.
Square come in all sizes as most are home made. I have seen square dogs for sale, so you would have to do your own research, but you are correct to get it all together b4 you build. Good luck a good bench is a big asset. My old bench can not compare to my new bench. A solid bench adds a lot to the precision of what you build.
And please see:
http://www.youtube.com/watch?v=Ktihu6UR0tM&feature=youtu.be
It’s all in the engineering.
-- Jeff NJ
JohnMcD348
#3 posted 02-18-2014 12:43 AM
Thanks You for the replies. Very Much appreciated.
Good info on the video, I hadn’t really given it much thought but the design I’m working on would take care of all that. I’m planning on actually having a stretcher at eh bottom and the middle. The bottom one is because I’ve found that when I’m standing at the tables, I like to have a step up, similar to the idea behind the foot bar at saloon bars. Also, by design, I’ll have a mid-height stretcher that will support a shelf
