Help with a chair's broken spindle
Forum topic by woodify posted 02-17-2014 03:25 AM 1542 views 0 times favorited 4 replies Add to Favorites Watch
View woodify's profile
woodify
284 posts in 1948 days
02-17-2014 03:25 AM
I have a chair with a broken spindle sitting in the garage collecting dust. When the spindle broke it splintered off a small piece which is now long gone. I tried gluing the spindle (when I had the small piece that had splintered) but it didn’t last long. After the last repair my preschooler noticed that the spindle was not aligned correctly (oops!) and tried to twist it back into place, lol…the glue didn’t hold.
What is the best type of glue to fix this and the best way to fill the small gap? I used yellow wood glue last time. I’m hoping I don’t need to spend the time to make a new spindle.
-- Woodify ~~ https://www.youtube.com/woodified
View bigblockyeti's profile
bigblockyeti
4906 posts in 1596 days
#1 posted 02-17-2014 05:01 AM
Yellow glue doesn’t fill gaps too well, and when it’s used that way usually isn’t very strong. Your best bet would probably be two part epoxy. You may have to create a little bit of a dam with tape to contain it as it sets, then sand down any rough or irregular areas. The longer cure time the better it will creep into all the little gaps resulting in few voids. Stay away from the 5 minute stuff.
View jerrells's profile
jerrells
918 posts in 2760 days
#2 posted 02-17-2014 01:47 PM
I would also try drilling a hole or two for dowels. Now I understand that will be a issue on one end, perhaps, but a repaired a different chair problem using this method and it worked great.
-- Just learning the craft my Lord and Savior Jesus Christ practiced.
View bondogaposis's profile
bondogaposis
4541 posts in 2227 days
#3 posted 02-17-2014 02:30 PM
The only fix that is going to last is to make a new spindle. The grain runs out on that spindle, that is why broke in the first place. If you fix it in one spot it will likely break in another.
-- Bondo Gaposis
View AandCstyle's profile
AandCstyle
2951 posts in 2133 days
#4 posted 02-18-2014 01:10 AM
You could try drilling a hole into both of the pieces and adding a short section of steel rod. Then epoxy, sand, etc. FWIW
-- Art
