Trouble cutting mortises in end rails
Forum topic by Pitt posted 02-16-2014 09:58 PM 896 views 0 times favorited 2 replies Add to Favorites Watch
View Pitt's profile
Pitt
35 posts in 3773 days
02-16-2014 09:58 PM
Topic tags/keywords: jig question router
Hi all
This is my first time trying floating tenons. I’m building a blanket chest and need to cut mortices into 5/4 rails (double mortices, to make it tougher).
I’ve tried a couple of different clamping jigs with my plunge router, but they are all unstable and move with the router. I end up with squiggly mortises…
What do you guys use?
Thanks
Pitt
2 replies so far
View Texcaster's profile
Texcaster
1274 posts in 1640 days
#1 posted 02-16-2014 11:44 PM
I have a slot mortiser but others make horizontal routers.
http://lumberjocks.com/projects/56897
A few notes on slot mortising:
The mortise in the end grain & long grain will be different sizes. Nothing to worry about but know which is which when you make the tenons.
Make the tenons from the same species. At a given setting on the planer, different species will be different thicknesses.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View AandCstyle's profile
AandCstyle
3027 posts in 2223 days
#2 posted 02-17-2014 01:34 AM
Pitt, I use the Mortise-Pal to cut the mortises for floating tenons. It is very accurate and is rock solid when clamped to the workpiece. It is also very easy to use. If I lost mine, I would replace it.
-- Art
