What is the primary bevel and second bevel of chisel?
Forum topic by anqi posted 01-01-2009 07:29 AM 2041 views 0 times favorited 5 replies Add to Favorites Watch
View anqi's profile
anqi
54 posts in 3698 days
01-01-2009 07:29 AM
I am planning to use the LV sharpening jig to sharpen my chisel as well. Thanks.
5 replies so far
View GaryK's profile
GaryK
10262 posts in 4224 days
#1 posted 01-01-2009 07:49 AM
The typical bevel on a standard chisel is 25 degrees. You can leave it at that without a secondary bevel.
A secondary bevel is usually about 2 degrees steeper and you just take a couple of passes on your stone.
This is used to make it easier to “touch up” the edge without doing the entire bevel.
View anqi's profile
anqi
#2 posted 01-01-2009 07:51 AM
Did you mean it apply to different size such as 3/8,....etc. Thanks
GaryK
#3 posted 01-01-2009 07:54 AM
The same thing applys no matter the width.
You sharpen a 3/8” exactly like you would a 1”
View ChuckM's profile
ChuckM
615 posts in 3903 days
#4 posted 01-02-2009 05:07 AM
Are you referring to this honing guide?
http://www.leevalley.com/wood/page.aspx?c=1&p=51868&cat=1,43072,43078
If so, click on the “Instr” blue icon and it will bring up the explanations in Figs. 7 and 8. Step 6 there shows you how to get the secondary bevel as in:
“With the micro-bevel knob in the 6 o’clock position, you will obtain a micro-bevel with a 1° to 2° difference from the primary bevel.”
This is the best honing jig in the market as rated by most woodworking magazines.
-- The time I enjoy wasting is not time wasted
View anqi's profile
anqi
#5 posted 01-02-2009 07:46 AM
yes, i have this jig. It is a great tool. Thanks.
