Forum topic by Edwin posted 02-15-2014 03:49 PM 1182 views 0 times favorited 15 replies Add to Favorites Watch
View Edwin's profile
136 posts in 2931 days
02-15-2014 03:49 PM
I need to glue a mirror to a frame that I made for my daughter in-law. The frame is made of oak 30” x 16”, It is a wall mounted jewelry box. It is the door to the box. Just the frame, Nothing behind it so that is the problem…Help…ED
-- Ed Port Republic
15 replies so far
View NoLongerHere's profile
893 posts in 2609 days
#1 posted 02-15-2014 04:04 PM
can’t you put a back on it? mirror backs aren’t very pretty. If you scratch it, you’ll ruin it too.
picture would help. what was there before?
might be better to remake the frame and dado it to hold the mirror and add a back – no glue.
View tinnman65's profile
1356 posts in 3347 days
#2 posted 02-15-2014 04:05 PM
I would guess some doulble sided carpet tape or a hot melt glue gun might do the trick. Good luck:)
-- Paul--- Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep. — Scott Adams
View Bill White's profile
Bill White
4878 posts in 3893 days
#3 posted 02-15-2014 04:05 PM
Sounds like an accident waitin’ to happen.
35112 posts in 4333 days
#4 posted 02-15-2014 04:09 PM
I wouldn’t use anything on the back because the silver coating is not a permanent place.
I would think about using some epoxy on the glass edge and gluing it into the frame. Someone else mentioned hot melt glue. that might also work. Clear Silicone caulk could also be a substitute.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware soon moving to Virginia †
117032 posts in 3510 days
#5 posted 02-15-2014 04:12 PM
Like Mark said your better off making it removable ,if you have to glue it use a mirror adhesive other types of adhesive will react with the mirror backing,
-- wood crafting & classes
View cajunpen's profile
14575 posts in 3999 days
#6 posted 02-15-2014 05:30 PM
I’m lost without pictures – I can’t picture what you are talking about. I normally use Silicone to adhere mirrors to wood. You only need a few dabs around the outer rim on the mirror and perhaps a couple of dabs in the center. Once dry you will have a heck of a time removing the mirror.
-- Bill - "Suit yourself and let the rest be pleased."
View bondogaposis's profile
4636 posts in 2284 days
#7 posted 02-15-2014 05:37 PM
Glass stops in a rabbet. I would use some plywood for backing though.
-- Bondo Gaposis
View Clint Searl's profile
Clint Searl
1533 posts in 2294 days
#8 posted 02-15-2014 06:05 PM
Mirror adhesive, duh.
View bigblockyeti's profile
5054 posts in 1654 days
#9 posted 02-15-2014 06:14 PM
A rabbet would be safer, using a little silicone around the edge will give you something that can be cleaned out if the mirror were damaged and needed to be replaced.
View distrbd's profile
2252 posts in 2379 days
#10 posted 02-15-2014 06:20 PM
Adhesive caulking in the corners and a couple of dabs in the middle should do it.
-- Ken from Ontario, Canada
View Todd's profile
398 posts in 1609 days
#11 posted 02-15-2014 06:42 PM
I made custom frames for the mirrors in our bathroom and used silicone to glue them on. It seems to hold really well. However, mine aren’t a door to anything. I made my frames with a rabbet so I agree with Bondo and yeti on that.
-- Todd, Huntsville, AL
View jim65's profile
995 posts in 1866 days
#12 posted 02-15-2014 07:47 PM
I have used silicon caulking for this type of thing before and it works, but a backing would be safe, a broken mirror is not a great thing.
-- Jim, Marostica Italy
View Jim Finn's profile
Jim Finn
2640 posts in 2855 days
#13 posted 02-16-2014 12:53 PM
As Jim Suggested doing…I have a 36” square mirror that I made the frame for and secured the glass with clear Silicone. This was in 1983 and it is still holding well.
View mahdee's profile
3852 posts in 1700 days
#14 posted 02-16-2014 01:39 PM
I wouldn’t use anything with adhesive in it. I did that a few times and trying to get a broken glass out becomes very tasking and dangerous. Made this medicine cabinet about 16 years ago from solid oak and the mirror is held with Plexiglas. I am sure there are all kinds of fasteners out there you can use to secure it in place without using adhesive.
View Wildwood's profile
2267 posts in 2068 days
#15 posted 02-16-2014 02:16 PM
I used epoxy to glue 3” bevel mirrors to wood I turned. Might try one of these products next time.
Also thought about trying auto products only because do not need much adhesive.
-- Bill
