Veneered torsion box or reclaimed slab
Forum topic by JustLikeJames posted 02-14-2014 08:27 PM 1062 views 0 times favorited 9 replies Add to Favorites Watch
View JustLikeJames's profile
JustLikeJames
173 posts in 1470 days
02-14-2014 08:27 PM
Maybe some of you that can understand wood grain better than I can help me out. I’d like to build a table similar to a table (the counter height one) from the Disney show Good Luck Charlie. Without seeing it in person or having a higher resolution picture I can’t tell if that’s a veneered torsion box or a reclaimed slab. I’m leaning towards an actual slab. Can anyone tell?
Pic 1
Pic 2
Next question. I can’t afford a reclaimed slab that size. Do you think that is doable as a veneered torsion box without looking fake (for lack of a better term)?
Thanks.
9 replies so far
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15133 posts in 2526 days
#1 posted 02-14-2014 08:33 PM
I’ve noticed that slab before, it’d make a great benchtop.
View jmartel's profile
jmartel
7687 posts in 2058 days
#2 posted 02-14-2014 08:37 PM
Judging by the bowing of the bottom in the first photo, I would guess it’s a slab that’s missing a small chunk in that area.
JustLikeJames
#3 posted 02-14-2014 09:33 PM
Good eyes jmartel. I hadn’t noticed that missing chunk before. I think that’s clear evidence that it’s a slab.
Smitty_Cabinetshop, It’s make a nice dining room table too. I just don’t know if I can get the same authentic look with a torsion box. I mean, it’s not like I could get end grain veneer to match the top. Maybe I’m overthinking it and no-one except other woodworkers would even notice the difference.
Thanks.
View Rick_M's profile
Rick_M
11133 posts in 2288 days
#4 posted 02-14-2014 10:12 PM
In real life you’d want a butcher block top but being a tv show prop it might be a torsion box, lightweight and easier to move/store.
-- http://thewoodknack.blogspot.com/
View DrDirt's profile
DrDirt
4421 posts in 3650 days
#5 posted 02-14-2014 11:10 PM
Suspect a slab – just because of the graining on the side, but also how it sits on a full steel frame, to be able to support the weight, and not move easily when standing at it.
Rick makes a great point though – that as a prop – i is likely from some other shows and gets moved around and put back on a shelf somewhere when they are using the studio for other shows.
View LiveEdge's profile
LiveEdge
572 posts in 1528 days
#6 posted 02-14-2014 11:27 PM
I would strongly suspect non-slab just due to the fact it is a prop on a stage. Slab is going to equal weight and cost.
But, it could be…
LiveEdge
#7 posted 02-14-2014 11:29 PM
The endgrain pattern looks way different between the two pictures. Repair? or did they rotate it 180 degrees? Still, the second looks very uniform while the first looks much wilder.
JustLikeJames
#8 posted 02-15-2014 03:34 AM
I appreciate the input everybody. All good points. Glad I joined the site.
Thanks
Smitty_Cabinetshop
#9 posted 02-15-2014 04:07 AM
My daughter watched the show a lot. There has been quite a bit of actual contact with that table, it’s solid as a rock.
James, there’s a recent blog started that has a method for making shelves look solid that’s worth taking a look at…
http://lumberjocks.com/KevinJeffery/blog/39891
