Jointer issues
Forum topic by Randy Moseley posted 01-01-2009 04:26 AM 1196 views 0 times favorited 5 replies Add to Favorites Watch
View Randy Moseley's profile
Randy Moseley
113 posts in 3680 days
01-01-2009 04:26 AM
Topic tags/keywords: jointer
Does anyone have problems with their jointer taking out a small bit at the end of the board (I believe it’s called snipe), making that last couple of inches narrower? I also have experienced a tapering effect when I make several passes. It’s gotten to the point that I don’t like to use my jointer that much, but resort to turning boards on their edge and running them through the planer. Any suggestions would be appreciated.
-- Randy, DeKalb, Illinois
5 replies so far
View Peter Oxley's profile
Peter Oxley
1426 posts in 4115 days
#1 posted 01-01-2009 04:43 AM
Randall – there are a couple of things that could be causing this. The most likely thing is that your infeed and outfeed tables are not quite parallel. This could cause both snipe and taper like you describe.
The other possibility is your technique. By the time about half of your board is past the cutterhead, both of your hands should be over the outfeed table. If you continue to push on the infeed side, you can take away too much material on the trailing end.
The jointer can be a little finicky to set up, and it can take some practice to use, but my advice is don’t give up! It’s a very useful machine.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View SPalm's profile
SPalm
5326 posts in 4123 days
#2 posted 01-01-2009 05:01 AM
Hey Randal,
As Peter says, it is probably the alignment of the two tables. There is a fairly good article by Gary Rogowski who goes through both jointers and hand planes, as the end result is achieved with both. Don’t give up, a jointer is a very nice tool to have. Buy some new blades, a dial indicator, and spend a little time getting to know it.
http://www.northwestwoodworking.com/article_1/article1.html
Good luck,
Steve
-- -- I'm no rocket surgeon
35154 posts in 4641 days
#3 posted 01-01-2009 05:03 AM
I agree on the alignment.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
Randy Moseley
#4 posted 01-03-2009 03:18 AM
Thanks, guys. I did some adjustments today and it’s working very well.
View henryj383's profile
henryj383
66 posts in 3672 days
#5 posted 01-03-2009 03:38 AM
Hello everyone, I am new to the stuff,not woodworking, this here computing stuff.. but I will try anything once, well maybe not!lol
Anyway I will get in to this as time goes on, it looks like a lot of fun..
Thanks again to everyone for the warm welcome!
