Festool lc45 charger
Forum topic by Posty posted 02-14-2014 01:57 AM 1960 views 0 times favorited 4 replies Add to Favorites Watch
View Posty's profile
Posty
67 posts in 1603 days
02-14-2014 01:57 AM
So I bought a c12 drill set and I plugged in the charger and charged a battery. It went solid red and I smelled smoke. Popped the top off the charger and found a burnt resistor. Was wondering if anyone who had this charger could take a picture of the circuit board so I can get the resistor color code to get another one. Here is a picture of the resistor location.
View Fish22's profile
Fish22
83 posts in 2986 days
#1 posted 02-14-2014 02:57 AM
Call festool service, they are great and may even send out what you need.
-- Bryan, South River, NJ
View Deycart's profile
Deycart
444 posts in 2131 days
#2 posted 02-14-2014 03:01 AM
I have some experience fixing electronics. Resistors rarely just go bad. That was caused by a short. You may have a shorted battery or a bad transistor somewhere. Look along the traces that connect to the resistor and you will likely fine another bad component or two.
Posty
#3 posted 02-14-2014 03:17 AM
It looked as off the connections were loose. Prob from being shipped to me and being an older charger. Also I forgot to mention that I happened after I cleaned everything off with some simple green. I made sure to only use a little cleaner on the charger but maybe some dropped down into the board.
View Pietr's profile
Pietr
1 post in 1120 days
#4 posted 12-27-2014 01:36 PM
I know it’s a late reply, but I hope it might help someone who stumbles upon this tread. The resistor color code is white-brown-brown hence 910 Ohms.
