Having router bits creeping
Forum topic by Kenny posted 02-13-2014 04:24 PM 1285 views 0 times favorited 12 replies Add to Favorites Watch
View Kenny's profile
Kenny
7 posts in 2742 days
02-13-2014 04:24 PM
Topic tags/keywords: question router
I am having router bit creeping out and ruining my work before I catch it.
I am contemplating installing a small groove in my bits and installing a split ring
above the collet to prevent this in the future.
Without a doubt this was caused by trying to cut too much too fast
causing the shank of the bit to spin.
The router is on a ,gunstock duplicator, so a little gouge ruins the blank.
Any suggestions. Kenny
-- Kenny, Ohio
12 replies so far
View Loren's profile
10477 posts in 3889 days
#1 posted 02-13-2014 04:31 PM
How tight are you making the collet?
(my rule is “a fair grunt” tight)
Cleaning collets regularly can help them perform well.
Sometimes with use a collet can wear out. I imagine
this would be mostly an issue if you acquire the equipment
used.
View jumbojack's profile
jumbojack
1685 posts in 2866 days
#2 posted 02-13-2014 04:40 PM
As Loren said CLEAN the collet. Seat the bit in the collet and back it out an 1/8 or so.
View Bill White's profile
Bill White
5149 posts in 4202 days
#3 posted 02-13-2014 05:16 PM
I don’t think that I would be cutting a groove in a bit shank. Too much chance for a fracture, and I don’t wanna be anywhere near a fractured router bit.
Bill
-- bill@magraphics.us
View SPalm's profile
SPalm
5326 posts in 4124 days
#4 posted 02-13-2014 05:24 PM
Clean the shank of the bit too. Burn marks are slippery.
I have worn out a collet before and had to buy a new.
Don’t groove the shank.
Have you tried a different brand? Like a real quality brand name?
Steve
-- -- I'm no rocket surgeon
View basswood's profile
basswood
261 posts in 1862 days
#5 posted 02-13-2014 05:45 PM
The shanks taper slightly near the business end, this causes bits chucked in too far to not be held firmly enough. This is why the posts above suggest backing the bit back out an 1/8” or so.
You can lightly sand the shanks (lightly abrading them) to help a collet hold on better. Too much of that and the collet may not want to let go though and when it does you may have to hike across the shop to retrieve it. So try all the other measures first.
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
View 7Footer's profile
7Footer
2569 posts in 2190 days
#6 posted 02-13-2014 06:18 PM
I had the same thing happening to me a few weeks ago while cutting some dados, the bit was creeping out over 1/4 inch when I got a couple feet into the cut. I finally realized what was happening and there were 2 things going on, one was like you said I was cutting too much stock at once, but the other was that my bit was not chucked deep enough into the collet. So once I set it as deep in the collet as I could I didn’t have any more problems, maybe there is a happy medium between getting it chucked far enough in like ^basswood said and not having it chucked far enough. Good luck!
-- http://www.youtube.com/nrk411
View pintodeluxe's profile
pintodeluxe
5820 posts in 3055 days
#7 posted 02-13-2014 07:00 PM
Once in a while a bit will be out of spec on the diameter, and won’t clamp well.
If a collet has ever had an 8mm bit chucked in it, it will ruin the collet.
If the shank of the bit, or the inside wall of the collet have been scored they should be replaced.
Good luck with it.
View upinflames's profile
upinflames
217 posts in 2404 days
#8 posted 02-13-2014 09:58 PM
The reason you back the shank out of the router 1/8” is the collet, when tightened, it squeezes and pushes down on the shank. If the bit is bottomed out it will seem tight and will creep out.
Kenny
#9 posted 02-13-2014 10:06 PM
Thanks for the help fellows.
Bill, the collet goes on the shank first and then the grooves with the snap ring
on the tail end up inside the router.
I fail to see how this could break or fracture as nothing would be touching
that end.
I cut the grooves so the collets have 1/8” end play on the shank.
I will do a good job of cleaning the collets and router bit shanks as
has been suggested.
-- Kenny, Ohio
View bigblockyeti's profile
bigblockyeti
5324 posts in 1962 days
#10 posted 02-13-2014 10:41 PM
What make and model router are you experiencing this problem with?
View CharlesA's profile
CharlesA
3361 posts in 2039 days
#11 posted 02-13-2014 11:15 PM
Cutting grooves on bits seems like a radical solution to a problem that should be easily solved.
View MalcolmLaurel's profile
MalcolmLaurel
300 posts in 1865 days
#12 posted 02-13-2014 11:15 PM
I’ve had the same problem with an older Craftsman router that was my father’s. Part of the problem in my case is that the shaft lock is worn so it’s hard to tighten it securely.
-- Malcolm Laurel - http://MalcolmLaurel.com
