Trees fallen because of ice.
Forum topic by davidmackv posted 02-13-2014 03:38 PM 1141 views 0 times favorited 15 replies Add to Favorites Watch
View davidmackv's profile
davidmackv
317 posts in 1644 days
02-13-2014 03:38 PM
I have some trees that have fallen, because of the ice storms that came through. I lost two 40 foot pines. What would you do with these trees? I don’t ever use pine for firewood, because the high sap content can burn your house down. Are they worth getting processed for wood working wood, or is pine so cheap it is best just to get someone to haul them off?
I also lost a 40 foot maple, but I am going to take it to the sawmill we have locally and get some boards.
Thanks
David
15 replies so far
View PineChopper's profile
PineChopper
187 posts in 2193 days
#1 posted 02-13-2014 04:04 PM
My chainsaw and I would be in heaven. I’d be looking for logs to build something out of.
99% of my firewood is pine and I’ve never had a problem with it. My wood stove and fireplace are my only source of heat. The other 1% of firewood is either oak, mulberry, or eucalyptus.
Do you plan to replant some more trees?
PineChopper
#2 posted 02-13-2014 04:07 PM
davidmackv
#3 posted 02-13-2014 04:12 PM
Interesting. I have never burnt pine, because my family and friends always told me it was a fire hazard , burnt too fast and wasn’t worth the effort. Well, I will just have to cut em up, dry em out and find out for myself. Thanks for the advice.
Actually I have 40 pines running across the back of my property to block the highway and noise and I lost two of them. I think they were planted too close together to start with, so probably not. My Father In Law and his father planted them over 30 years ago. Heck they may be 60 foot tall the 40 was just a guestimate.
View b2rtch's profile
b2rtch
4861 posts in 3045 days
#4 posted 02-13-2014 04:27 PM
I burn pine in my stove all the time.
Make sure it is well season.
In France it is illegal to burn pine in a stove or fireplace and if you get fire , the insurance will not cover you.
All pines: are not equal.
I love Douglas Fir to make furnitures
-- Bert
View helluvawreck's profile
helluvawreck
31056 posts in 2863 days
#5 posted 02-13-2014 04:32 PM
I hope I don’t loose any. I have trees all around my house. We’re in North Georgia so we got mostly snow. We did get some ice but hopefully we’ll make it through today without loosing any power or trees. Of course my main concern would be a tree coming down on my shop or the house.
helluvawreck aka Charles
View bigblockyeti's profile
bigblockyeti
5112 posts in 1717 days
#6 posted 02-13-2014 04:40 PM
If you have multiple mills not too far away, having them cut up might be a worth while venture. See if they charge by the cut or by the board foot. The logistics are something to consider as well, if you can haul the wood to the sawyer, that will save a little as well.
View jumbojack's profile
jumbojack
1676 posts in 2620 days
#7 posted 02-13-2014 04:44 PM
I’ve burned pine in my stove for as long as I can remember. Clean the chimney once a year or so and you are golden. If the trunks are substantial, I would mill the straightest ones, saving all the branches and crooked or knot infested trunk areas for the stove/fireplace.
View bondogaposis's profile
bondogaposis
4725 posts in 2347 days
#8 posted 02-13-2014 04:45 PM
If the pines are full limbs and hence the wood will have a lot of knots I wouldn’t bother. On the other hand if it is clear I would consider having it milled.
-- Bondo Gaposis
davidmackv
#9 posted 02-13-2014 04:50 PM
The bottom trunks are clear of limbs for at least 15 feet and are straight as an arrow. My sawmill charges .50 a BF to saw and an extra .50 BF to kiln dry.
b2rtch
#10 posted 02-13-2014 04:56 PM
Save it, there is nothing like using your own lumber to build something.
I used to have my own sawmill
-- Bert
View richardwootton's profile
richardwootton
1699 posts in 1951 days
#11 posted 02-13-2014 05:01 PM
Dang $1.00 per bd. fot. sounds a bit on the steep side
-- Richard, Hot Springs, Ar -- Galoot In Training
bigblockyeti
#12 posted 02-13-2014 05:27 PM
That seems ok for cutting, little steep for drying, guess it depend on when you need it and how much space you have to dry it yourself properly.
View HerbC's profile
HerbC
1755 posts in 2856 days
#13 posted 02-13-2014 09:30 PM
Have the straight, clear pine logs milled into lumber. Do not pay to have them dried. Sticker stack them outside and air dry them. It will make excellent general use lumber. Should take less than a year to air dry. Be sure to cover the stacks to prevent exposure to sun and rain but don’t use plastic or tarps. Use old roofing tin if you can get it cheap, or old plywood.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Don W's profile
Don W
18711 posts in 2564 days
#14 posted 02-13-2014 09:35 PM
I saw pine. If you can get it sawn for 30 or 40 cents a foot that’s about 1/3 the retail.
davidmackv
#15 posted 02-13-2014 10:30 PM
Thanks for the info everyone. It is much appreciated.
