Delta Downdraft Table , Good or Bad?
Forum topic by Cruiszr posted 02-13-2014 01:54 AM 2315 views 0 times favorited 5 replies Add to Favorites Watch
View Cruiszr's profile
Cruiszr
88 posts in 1832 days
02-13-2014 01:54 AM
I have had a Delta downdraft table that I got at Lowes 3 or 4 years ago on clearance and was trying to lay out my workshop and wondered if I should try and incorporate into one of my work benches. I have been reading reviews about prefab downdraft table and it seems like the response has been less than favorable. Before I make a final decision about this I would like to get some opinions from LJ. Your input would be appreciated.
-- George R. Forest, Virginia
5 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 3090 days
#1 posted 02-13-2014 03:57 AM
Getting some of the dust away from your lungs is better than getting no dust away. And, because you’re a skilled woodworker, you can always remove it and adapt the bench to something different whenever you want to.
Go for it!
Kindly,
View Grandpa's profile
Grandpa
3261 posts in 2915 days
#2 posted 02-13-2014 04:06 AM
+1 what Lee said
View Bill7255's profile
Bill7255
428 posts in 2525 days
#3 posted 02-14-2014 08:18 PM
I got one also and only used it a couple of times. Agree if you need one you should use this or make one. My current plan is to put it behind my lathe for lathe sanding. This seems a better use for me than as a downdraft table.
-- Bill R
View Kelly's profile
Kelly
2187 posts in 3184 days
#4 posted 02-14-2014 09:15 PM
There is no reason you can’t add a scoop (like a back splash) to the back. I have 4×4 piece of Masonite I drilled a gazillion holes in, set on a six box [with a bottom] and it helps a lot, with my dust collector tied to it via a 4” hole.
I’m thinking of building another, but slanting the bottom and enlarging the holes.
Using the one I have, I lay window shade vinyl (the roll up kind) on the unused areas to increase air flow where I’m working.
View 7Footer's profile
7Footer
2569 posts in 2188 days
#5 posted 02-14-2014 09:29 PM
Yeah I’m with Lee. I just made a little mobile workstation with a downdraft box build into it and so far I love it, although I’ve only used it a couple times, its very handy, I am in desperate need of dust collection so anything helps me out.
I made mine with a removable cover so I can still have some bench space when I’m not using it.
-- http://www.youtube.com/nrk411
