Tablesaw sled
Forum topic by DKV posted 02-13-2014 01:05 AM 2208 views 0 times favorited 30 replies Add to Favorites Watch
View DKV's profile
DKV
3940 posts in 2411 days
02-13-2014 01:05 AM
If I have an accurate mitergauge why do I need a crosscut sled? Many times I’ve thought of building one but can’t find the justification to do so.
-- This is a Troll Free zone.
30 replies so far
View madts's profile
madts
1842 posts in 2246 days
#1 posted 02-13-2014 01:25 AM
Make one for yourself. Then you will know. I have 3. One for 45 degs. frames and such. One for large stuff, and one for small things. Hardly ever use the miter gauge. Also have a bunch of other sleds. Same principle.
-- Thor and Odin are still the greatest of Gods.
View jtritz's profile
jtritz
38 posts in 1530 days
#2 posted 02-13-2014 01:26 AM
Maybe I’m missing something in your post or picture, but in my limited experience I would say this IS a crosscut sled. Any LJ veteran want to correct this rookie (me) or am I on the right track here??
View sawdustjunkie's profile
sawdustjunkie
379 posts in 1624 days
#3 posted 02-13-2014 01:37 AM
Last spring I was in my garage shop and didn’t think I needed one either, until I had a kick back that threw a piece of wood into my chest! It hit me so hard I thought I broke some ribs.
I went to my knees and stayed there for almost 2 min.
I was ok after that and 4 days later I had a black n blue mark all the way across my chest.
Now I use one for almost all my cuts.
-- Steve: Franklin, WI
View CharlesA's profile
CharlesA
3305 posts in 1704 days
#4 posted 02-13-2014 01:41 AM
I think a crosscut sled is smoother and more stable than a miter gauge. I always feel more in control with a sled than using the miter gauge. I suppose it is possible, but kickback seems almost impossible with a good sled.
@jtritz: That’s just a miter gauge with a auxiliary fence attached. I think a minimum definition of a sled would include the bottom piece.
View DKV's profile
DKV
#5 posted 02-13-2014 02:01 AM
jtritz, I’ve always thought the way you do.
CharlesA, the only time I’ve ever had a kickback was when using a fence while ripping. I seldom use my miter saw to crosscut. I do admit most of my crosscuts are on boards no longer than 4’ and I’ve never crosscut a board wider than 12”. I think the odds of a kickback using a mitergauge are no worse than a sled. Am I seeing things wrong?
View distrbd's profile
distrbd
2252 posts in 2353 days
#6 posted 02-13-2014 02:13 AM
I also use my miter gauge to cross cut but find a sled is a better/more appropriate tool if the piece I’m cutting is longer than 36” & wider than 10”.less drag .
-- Ken from Ontario, Canada
CharlesA
#7 posted 02-13-2014 02:33 AM
Not sure. The reason I mentioned kickback is that the wood on my sled seems so solid and secure—less,so,with miter gauge. It seems to me the wood could get out of line with the blade easier with the miter, but that’s just me.
View Kryptic's profile
Kryptic
294 posts in 1567 days
#8 posted 02-13-2014 03:00 AM
they are all brutal
like putting your favourite great grand parent on the longest tobogganing hill and making them walk back up pulling their own toboggan back up the hill
Festool, like a snow machine, makes life better
View DIYaholic's profile (online now)
DIYaholic
19538 posts in 2582 days
#9 posted 02-13-2014 03:02 AM
Since it is winter, I’m going sledding….
I hope a sled is the “right” way to go….
Otherwise, the one I’m building would be “wrong”!!!
View sras's profile
sras
4749 posts in 3036 days
#10 posted 02-13-2014 04:31 AM
Large pieces seem to work better on a sled (if it is a large sled) – either very wide or very long
Sleds can be built to limit travel such that the blade does not show up past the fence
For some reason, I find it easier to keep my hands farther away from the blade with a sled. I’m not sure why. All I know is I feel safer.
View SawdustTX's profile
SawdustTX
265 posts in 2230 days
#11 posted 02-13-2014 04:39 AM
And a sled provides an automatic zero clearance “insert” on both the bottom and back (exit) of the cut. Zero tearout.
View Rick_M's profile
Rick_M
11121 posts in 2287 days
#12 posted 02-13-2014 05:05 AM
People originally built sleds because most miter gauges were terrible and relatively small, if you are happy with yours then maybe you don’t need a sled. I have 2 sleds and prefer them for crosscutting, better control.
-- http://thewoodknack.blogspot.com/
View waho6o9's profile
waho6o9
8100 posts in 2483 days
#13 posted 02-13-2014 05:07 AM
I like sleds because you can place hold downs
where ever you want, or install t tracks and build
sliding hold downs, very versatile.
View DKV's profile
DKV
#14 posted 02-13-2014 05:28 AM
I guess if I had to have one this would be the one.
View Texcaster's profile
Texcaster
1271 posts in 1580 days
#15 posted 02-13-2014 06:31 AM
This is the only miter gauge I’ve ever had that will take the pace for heavy work. I had to rework it a bit when I first bought it. A pin at the end locks in 90*.
-- Mama calls me Texcaster but my real name is Mr. Earl.
showing 1 through 15 of 30 replies
