Insulation Cures Cabin Fever
Forum topic by changeoffocus posted 02-12-2014 01:37 AM 1034 views 0 times favorited 3 replies Add to Favorites Watch
View changeoffocus's profile
changeoffocus
467 posts in 1645 days
02-12-2014 01:37 AM
I’ve seen a number of posts mentioning shops being shut down because of lack of heat.
If you are using power tools and lights all it takes is constructing an envelope that can be sealed in one way or another to allow you to insulate the walls.
You don’t need to do the whole space, the lights and equipment running will take care of the heat.
As to the LJ’s using only hand tools, I’ve done a little work with plane and needing heat was the least of my worries.
Just trying to help cure some cases of cabin fever.
RMC
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3740 days
#1 posted 04-16-2014 03:25 AM
Ummm, i don’t know how cold it gets in Indiana but here in Manitoba my tools aren’t going to generate enough heat by themselves to warm up my shop LOL!
View bondogaposis's profile
bondogaposis
4769 posts in 2379 days
#2 posted 04-16-2014 03:48 AM
Ditto, for Montana.
-- Bondo Gaposis
Shawn Masterson
1325 posts in 1976 days
#3 posted 04-17-2014 02:00 AM
I live within 100 miles of you, and your nuts. I have a well sealed insulated detached shop(26×30). If I didn’t light the stove at least once every other day it would drop well below freezing. This past winter was nuts, -40* windchill.
