Need some insight on tuning my Stanely No. 4
« back to Hand Tools forum
Forum topic by Steve Diogo posted 02-11-2014 07:32 PM 1448 views 0 times favorited 25 replies Add to Favorites Watch
View Steve Diogo's profile
Steve Diogo
89 posts in 1826 days
02-11-2014 07:32 PM
Hi, all. Hoping you can give me some insight on tuning this Stanley #4. From everything I’ve seen and read, I believe the mouth is supposed be really tight. On this one (my first plane) I have the frog all the way forward, but with the blade set at the correct depth to get a nice, thin shaving, the mouth seems awfully wide open. Am I setting something incorrectly or is there a problem with the plane? I’m happy with the performance, but I don’t know what a perfectly tuned plane feels like.
Thanks,
Steve!
-- http://chicagowoodworker.wordpress.com/
25 replies so far
View Airframer's profile
Airframer
3043 posts in 2187 days
#1 posted 02-11-2014 07:39 PM
Is that Maroon japanning?
From the shape of the frog and if that is Maroon than it probably isn’t anything you are doing wrong. That would make it a much newer model and as such was starting the downhill slide in quality. It probably had a larger mouth new in the box.
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
View ksSlim's profile
ksSlim
1290 posts in 3124 days
#2 posted 02-11-2014 07:42 PM
Does it make shavings?
-- Sawdust and shavings are therapeutic
View JayT's profile
JayT
6002 posts in 2445 days
#3 posted 02-11-2014 07:44 PM
Two things
A) +1 to Airframer
B) Tight mouth is overrated—they are nice, but not completely necessary except on a few occasions with very tear-out prone wood. A truly sharp iron with a correctly mated and set chipbreaker will do wonders, even with an open mouth.
Steve Diogo
#4 posted 02-11-2014 07:52 PM
It is maroon, Air.
kss, yes, the shavings are full width and thin—now that I’ve learned how to sharpen. Interestingly, my No. 5, which I bought just after this one and should have a wide open mouth, has a super tight mouth. I had to set the frog back just to get the blade to protrude. Here’s the frog on the 5.
View b2rtch's profile
b2rtch
4868 posts in 3282 days
#5 posted 02-11-2014 08:02 PM
If your frog already is all the way forward, there is nothing you can do.
Or, if you do not mind modifying your plane, may be elongate the holes in the frog so that would move the frog forward a little more.
Another solution , go buy a wood-river plane, the price is very reasonable and they are excellent plane.
Wood rivers are sold by woodcraft.
http://www.woodcraft.com/Product/2021170/29725/WoodRiver-4-Bench-Hand-Plane-V3.aspx
-- Bert
b2rtch
#6 posted 02-11-2014 08:02 PM
The Woodriver hand planes are made in china by a company named Quangsheng.
They are excellent.
http://www.youtube.com/watch?v=QXUVzviBjCs
Here is another video by Christopher Schwarz about the quality of these made in China Woodriver planes:
http://www.popularwoodworking.com/article/smashing_planes_video
-- Bert
View Don W's profile
Don W
19034 posts in 2802 days
#7 posted 02-11-2014 08:42 PM
About the only want to tighten the mouth is buy a thicker aftermarket iron, but as already stated, if its not broke, don’t fix it. It should work as is. Keep the cutter sharp and the chip breaker close.
View Mike67's profile
Mike67
97 posts in 3570 days
#8 posted 02-11-2014 09:11 PM
Hard to tell but from the looks of the picture there’s paint where the blade contacts the frog. Look at your #5 and there isn’t any. That should be a perfectly flat surface to best support the blade. If your blade is sharp and you can’t get the plane to cut well, I think I’d start by rubbing that frog over some sandpaper glued down to a flat surface like a jointer table. You’ll have to work around the little nub that adjusts the blade and the rivet on the lateral adjuster, but just taking down any nubs or high spots in the paint could help.
View DocBailey's profile
DocBailey
584 posts in 2594 days
#9 posted 02-11-2014 09:28 PM
Do you really have it all the way forward (B) , or do you have it set so that the face of the frog is aligned with the machined angle in the sole (A)?
TheWoodenOyster
1317 posts in 2169 days
#10 posted 02-11-2014 09:50 PM
If it is working and giving you good, clean shavings, I wouldn’t worry about it too much. I am with JayT when he says that the interaction between the chipbreaker and iron are much more important than the mouth opening. I have noticed a significant difference in performance when I vary the chipbreaker tip location. I haven’t noticed much based on the mouth opening
-- The Wood Is Your Oyster
Steve Diogo
#11 posted 02-11-2014 10:35 PM
Really appreciate the posts. I think I’ll stick with the general consensus and be happy with the fact that it performs well. Doc, you’re right: I have it set like image a. And Bert, I have my eye on a couple of Wood Rivers.
DocBailey
#12 posted 02-11-2014 10:41 PM
Don’t want to beat this to death, but if yours is set like figure A, yet you could move it forward, it is fine to do so.
The bevel is not supported on a bevel down plane.
Smitty_Cabinetshop
15790 posts in 2852 days
#13 posted 02-11-2014 10:54 PM
Doc has it right, and that’s what the pictures show: the frog is not as far as forward as it could go for a tighter mouth. The name for the color I’ve seen is cordovan. My dad’s smoother is the same make / model, and is a solid performer. The last USA-made bench plane line was this color, and is not typed specifically in any of the studies I’ve found.
They get no respect at all, I tell ya.
View bandit571's profile
bandit571
21970 posts in 2917 days
#14 posted 02-11-2014 10:59 PM
All the bench planes I’ve rehabbed, I start them out as in Photo “A”, then go from there IF needed. Most don’t, and they work just fine. I do find that the more like Photo “B” I get, chatter starts to show up. Atleast on the “Non-Premium” planes.
I think I MIGHT have one of them Cordovan 9-1/2 block planes, sitting around…...
Steve Diogo
#15 posted 02-11-2014 11:00 PM
