cutting board
Forum topic by Joe Weaver posted 02-11-2014 06:37 PM 1308 views 1 time favorited 7 replies Add to Favorites Watch
View Joe Weaver's profile
Joe Weaver
518 posts in 3891 days
02-11-2014 06:37 PM
Topic tags/keywords: question walnut
I have a real nice piece of walnut that I would like to make a cutting board out of. My question is the piece of walnut has some cracks in it. I use tribond 3 with is non toxic. and water proof. Can I fill the cracks with titebond 3 and rub walnut sawdust in the crack. Would it be safe to use?
Thank you
Joe
-- Joe, Ga
7 replies so far
View moshel's profile
moshel
865 posts in 3889 days
#1 posted 02-11-2014 06:49 PM
IMHO it will be safe, but might be a bit hard on your knives. the glue dries to be very hard and will dull knives very quickly. Also make effort to mask around the crack while filling with glue as the excess glue will create an area with different finish (It will repel the oil). Alas, i have no good solution for this. how wide is the crack? can you send pic?
-- The woods are lovely, dark and deep, but I have promises to keep...
Joe Weaver
#2 posted 02-11-2014 07:04 PM
Here are pictures both sides
-- Joe, Ga
moshel
#3 posted 02-11-2014 07:16 PM
It is very pretty… My suggestion would be to either leave it as it is or fill it carefully like you suggested and use it as a serving, not cutting board. maybe cutting bread. another option would be to route a circular place for bowl over the knot and use it for serving dips.
View degoose's profile
degoose
7245 posts in 3560 days
#4 posted 02-11-2014 10:08 PM
For cracks this size… I use a 2 pack epoxy… when dry it sands very well and there is only a very small area of epoxy left to show…most finishes are food safe after curing for 7 days.
View eddy's profile
eddy
939 posts in 3570 days
#5 posted 02-12-2014 12:32 PM
yes use epoxy color it with fine sawdust from 220 sanding and all will be good
-- self proclaimed copycat
View WDHLT15's profile
WDHLT15
1793 posts in 2681 days
#6 posted 02-12-2014 09:51 PM
Black epoxy would offer a very nice contrast in walnut. So, instead of trying to hide the cracks, you might consider featuring them.
View lumberjoe's profile
lumberjoe
2899 posts in 2454 days
#7 posted 02-12-2014 10:05 PM
I use CA. ethyl-2-cyanoacrylate is a lot safer than methyl 2-cyanoacrylate. I lay down some thin then just start sanding with 150 grit while the CA is still setting up. You can’t even tell the cracks where there.
This won’t do much if they are structural – like crappy glue-ups for example but should work well for what you have there.
That’s a sweet looking piece of walnut
