I need an electrician, and I'm too cheap to pay one
« back to Coffee Lounge forum
Forum topic by hairy posted 02-11-2014 03:52 PM 1377 views 0 times favorited 20 replies Add to Favorites Watch
View hairy's profile
hairy
2595 posts in 3403 days
02-11-2014 03:52 PM
I want to remove the dimmer switch for my dining room lights and replace it with an ON/OFF toggle switch. There are six 65watt can lights in the ceiling. There is only 1 conduit to the box. There is also an ON/OFF toggle switch on another wall that will control these same lights.
Here’s a crappy diagram that I drew.
The dots in the center is the wiring connection. If I remove the switch from the drawing I just have the wires at the top. I think I should connect white to bare, and red to one side of the new switch and black to the other. I’m not sure where that idea came from, but it is stuck in my head.
What is the correct way to do this? THANKS!!!!!
-- My reality check bounced...
20 replies so far
17203 posts in 1727 days
#1 posted 02-11-2014 04:08 PM
That sounds like a 3 way switch, but I’ve never heard of a dimmer for a 3 way. If it’s a 3 way, you’ll need a 3 way switch. A 3 way switch has 3 connections, one for the power and 2 for the travelers. I can’t identify what’s what from the picture.
hairy
#2 posted 02-11-2014 04:08 PM
Maybe I need a certain type of switch?
oops! didn’t see your post
hairy
#3 posted 02-11-2014 04:10 PM
The drawing is an attempt to clarify the picture.
View MarcusM's profile
MarcusM
57 posts in 2851 days
#4 posted 02-11-2014 04:16 PM
Hairy, that’s a 3-way dimmer, and the other toggle switch will be a 3-way switch as well…so you’ll have to get a 3-way switch to replace that dimmer. You’ll have to determine which of the white, black or red wire is the common (yank the other switch and look at how it’s wired; the one that is connected on the side of the switch with the single contact/screw should be the common, so just hook that wire, whatever its color to the single contact side of the new switch. The rest will hook up the same way as on the dimmer. The white wire is not a neutral in this case, it’s part of the 3-way circuit and cannot run to ground. If the new 3-way switch has a ground terminal (some do some don’t) connect the bare wire to it. HTH.
Mark
-- Tilbilly Mark
#5 posted 02-11-2014 04:24 PM
I’m no electrician. I’ve done a lot of wiring, but 3 ways baffle me. There are a few different ways they can be wired depending where the light is in line. Hopefully someone will be along to say definitively what you’ve got going on. In the meantime I would do some google searches on 3 way circuits. There are some good pictures out there that may help. I don’t want to tell you anymore, because like I said, 3 ways baffle me.
#6 posted 02-11-2014 04:25 PM
Good answer Mark. It was that white wire that I was worried about. Figured it wasn’t neutral.
View DrDirt's profile
DrDirt
4418 posts in 3613 days
#7 posted 02-11-2014 04:56 PM
Mark is right – the red is usually the runner.
Test the switch before you screw it back into the wall.
View crank49's profile
crank49
4028 posts in 2842 days
#8 posted 02-11-2014 04:59 PM
Hope this image is readable.
Can’t see it on my PC. Some kind of network security thing.
At any rate, this is how a 3-way is supposed to be wired.
Power from the breaker panel comes in on the left side of the diagram.
Switched power going to the light(s) goes out the right side of my diagram.
Power only flows through the solid lines. The light is off as drawn.
Flip either switch and you will have a solid path for the power to flow.
In the past, some electricians did everything with black and white wires only. No red.
They might have used a white wire instead of the red for the interconnect between the switches.
In some cases I have even seen the bare ground wire used as the neutral. Not to code, but it exists.
hairy
#9 posted 02-11-2014 06:32 PM
Thanks for the pictures, but I don’t think they apply here. They both show a conduit going in and another going out of the switchbox. Mine has only one conduit with 4 wires..
Here’s a better pic of the wires.
Checking with a tester, the black/white connection is always hot. The black/red and the red/red turn on and off with the switch. I wrapped my hand around the connection being tested to prevent a reading from the other wires.
Here’s the 3 way switch I want to use, and my tester.
I’m thinking white to the black(common) terminal, red to 1 of and black to the other brass screws, bare to the green screw for ground.
I think I read somewhere if using white for hot that you put a piece of tape on it to signify hot. This is not. Maybe it’s in the other switchbox.
I’m changing the switch because the lights flicker like there’s arcing in the switch.
See all the fun you miss when you’re not a cheapo like me?
hairy
#10 posted 02-11-2014 10:02 PM
If you are keeping score at home, this worked. Thanks!
View exelectrician's profile
exelectrician
2327 posts in 2298 days
#11 posted 02-11-2014 10:25 PM
Hairy what you are doing is “HAIRY”
You may have destroyed the switch you have by creating a dead short.
You may need to go buy a new 3 way switch.
Connect the Black wire that is always Hot to the screw that is painted Black.
Connect the Red wire (that is alternately hot when you flip the other switch) to one of the gold screws.
Connect the White wire (that is alternately hot when you flip the other switch) to the only gold screw left to use.
Connect the bare copper wire to the Green painted screw. (I would cut off the green wire on the dimmer which is connected to the short bare wire and connect the green wire to the green screw.)
When you finally get this done let us know if you are still alive and kicking!
-- Love thy neighbour as thyself
View Belg1960's profile
Belg1960
1054 posts in 2936 days
#12 posted 02-11-2014 11:59 PM
The white in this case goes on the black screw. the other two wires can go on either of the brass colored screws and the bare wire goes to the green screw. Remember to wrap your wire in a clockwise hook around the screws. If your using the one you show in the picture you can just cut them to a straight end and slip them between the two metal plates and tigthen the screws. Remember this is going from the info you have provided.
-- ***Pat*** Rookie woodworker looking for an education!!!
#13 posted 02-12-2014 12:22 AM
From what you said you did and your description of what was hot all of the time, I think you did the right thing.
hairy
#14 posted 02-12-2014 12:27 AM
Thanks!
Yes, Belg1960, that is the way I did it, and it works. No smoke, no sparks and I don’t have to turn on the lights with a stick.
View Rick's profile (online now)
Rick
8539 posts in 2904 days
#15 posted 02-12-2014 01:29 AM
“exelctrician” nailed it pretty good.
Not trying to be a Smart Ass BUT! You’re to cheap to hire an electrician? Do you have Homeowners Insurance?
I’d keep a Close Eye on this and any other electrical work that you do.
IF! There is a Fire and they trace it back to an Electrical Problem that WASN’T done by a Qualified Electrician.
I do believe You Have a Major Problem. The Insurance Company will send you a nice letter saying …”Sorry. But. You’re NOT Covered. $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
-- A Chip On The Shoulder Usually Indicates Wood Higher Up. (Rick, Ontario, Canada)
