Help with filler
« back to Woodturning forum
Forum topic by Fjgold posted 02-11-2014 01:09 PM 1083 views 1 time favorited 12 replies Add to Favorites Watch
View Fjgold's profile
Fjgold
6 posts in 1533 days
02-11-2014 01:09 PM
Topic tags/keywords: question
I have a turning that has many checks and voids in the wood. I would like to fill these with a bright color material but not crushed stone or metal. What should i use – epoxy? CA glue? and how to add the color agent.
Any help or thoughts would be appreciated.
Fred
-- Fred, Los Angeles
12 replies so far
View Nubsnstubs's profile
Nubsnstubs
1282 posts in 1697 days
#1 posted 02-11-2014 01:50 PM
Inlace is a pretty common filler found at Woodcraft, Craftsupplies, and other wood hobby stores. It’s a plastic powder or granules, comes in colors and you just put it in the crack, pour in some CA, and then turn it smooth. Depending on the crack or void, it’s not as easy as I just wrote. Larger voids might need to be backed up with masking tape, or something that can be turned off. Hopefully others will chime in with their methods of filling voids and cracks…....... Jerry (in Tucson)
Fjgold
#2 posted 02-11-2014 03:45 PM
Jerry,
Thank you – i will look into it.
Fred
View madts's profile
madts
1855 posts in 2307 days
#3 posted 02-12-2014 01:35 AM
Epoxy with some colored filler in it. Strong strong. Do not use the 5 minute epoxy.
-- Thor and Odin are still the greatest of Gods.
Fjgold
#4 posted 02-12-2014 04:09 PM
Thank you
View Woodknack's profile
Woodknack
11483 posts in 2347 days
#5 posted 02-12-2014 04:19 PM
Something to keep in mind, CA glue is clear, epoxy is muddy. You can color epoxy with food coloring though.
View Glen Peterson's profile
Glen Peterson
556 posts in 3024 days
#6 posted 02-12-2014 09:29 PM
I often use gap filling CA mixed with sanding dust from the piece.
Cheers
-- Glen
Fjgold
#7 posted 02-12-2014 09:31 PM
Thanks Glen. I need the color though
Nubsnstubs
#8 posted 02-12-2014 10:11 PM
Try coffee grounds and CA…..... Jerry (in Tucson)
Woodknack
#9 posted 02-13-2014 01:42 AM
I have used sanding dust and ca glue, works really well. I add a drop of glue, pack it with sawdust then add another drop of glue on top.
View BigRedKnothead's profile
BigRedKnothead
8513 posts in 1950 days
#10 posted 02-13-2014 01:53 AM
Depending on the size of the crack or flaw, I used superglue and saw/sanding dust….or epoxy and sanding dust. This was what Sam Maloof and many respected woodworkers preferred as well.
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
View Split's profile
Split
33 posts in 1707 days
#11 posted 02-13-2014 02:00 PM
A two part epoxy will work well ca glue will dry too fast and to color it you should be able to use a pigment die. I have purchased powder and liquid pigment due off amazon.
Fjgold
#12 posted 02-13-2014 03:30 PM
Thank you all for the advice. I really appreciate the input.
