Dewalt DW735 13in Planer
Forum topic by mark76wa posted 02-11-2014 06:37 AM 1341 views 0 times favorited 9 replies Add to Favorites Watch
View mark76wa's profile
mark76wa
97 posts in 3365 days
02-11-2014 06:37 AM
I took it out of the box and set it on a shelf for a while. Now I need to use it and I find out that the rollers aren’t pulling the wood through.
Any suggestions?
9 replies so far
View yambo1's profile
yambo1
5 posts in 2292 days
#1 posted 02-11-2014 10:50 AM
I put a good coat of wax on mine and keep it waxed – works great. I had the same problem when it was new.
-- Yale
View johnstoneb's profile
johnstoneb
2872 posts in 2142 days
#2 posted 02-11-2014 01:47 PM
Clean the rollers and wax the bed. I’m assuming the feed rollers are turning.
-- Bruce, Boise, ID
View BenI's profile
BenI
332 posts in 2148 days
#3 posted 02-11-2014 03:54 PM
+1 to waxing the bed and cleaning the rollers.
Also, I’ve heard that if the temps are low the rollers don’t feed the wood very good
-- Ben from IL
View lepelerin's profile
lepelerin
495 posts in 2295 days
#4 posted 02-11-2014 03:56 PM
clean the roller with MS and wax the bed, that’s what I do with mine. Just did it yesterday as a matter of fact.
Enjoy the noisy machine )
View bullhead1's profile
bullhead1
228 posts in 2219 days
#5 posted 02-11-2014 05:28 PM
I agree with the waxing. Also don’t try to take too much off at a time. An 1/8th at the most. 1/16th if really hard wood.
View PurpLev's profile
PurpLev
8534 posts in 3618 days
#6 posted 02-11-2014 05:31 PM
clean rollers,
wax bed,
make sure it’s not freezing temperatures in your shop area as the rubber on the rollers will harden up and be more like “smooth plastic” than “grabbing rubber”
View juniorjock's profile
juniorjock
1930 posts in 3735 days
#7 posted 02-11-2014 05:33 PM
Mark, you talking about a brand new DW735? You shouldn’t have any trouble with a new one. All the guys are leading you in the right direction, but if it still gives you trouble after a little cleaning – send it back.
View DrDirt's profile
DrDirt
4423 posts in 3712 days
#8 posted 02-11-2014 06:38 PM
I would fire it up and switch between fast and slow feed a couple times, and see if there is something wrong with the feed drive not engaging.
Does it pull but not have enough traction? (dirty rollers)
Or do you not feel it grab the wood and try to pull at all?
mark76wa
#9 posted 02-11-2014 06:50 PM
Thanks everyone. I will wax the bed and try it aging this weekend. The temp here has been very low as well so that may be a contributing factor. I was not able to tell if the rollers were actually turning so I’ll check that again and let you know.
