Air pressure gauges - do they just wear out or is there a way to maintain them?
Forum topic by Loren posted 02-10-2014 03:43 PM 1005 views 0 times favorited 6 replies Add to Favorites Watch
10244 posts in 3610 days
02-10-2014 03:43 PM
I have some gauges that don’t work very well anymore and
I’m wondering if there’s something I can do to service them
or do I need to replace them to get accurate readings?
View Paul2274's profile
Paul2274
330 posts in 3075 days
#1 posted 02-10-2014 04:08 PM
May just need calibration… see if there is a way to adjust the readout.
Also… if you are using a compressor, check to make sure you don’t have water in your tank… or if you have a separator that it is working properly…. both of these can cause corrosion and the gauge to go bad internally.
View MrRon's profile
MrRon
4710 posts in 3206 days
#2 posted 02-10-2014 04:26 PM
Go to: www.surpluscenter.com They have any pressure gauge you want at very affordable prices.
View Grandpa's profile
Grandpa
3259 posts in 2638 days
#3 posted 02-10-2014 04:43 PM
I specified gauges in a past life. I say they do wear out just like your watch wears out. In the price range of most of our gauges just toss it and buy a good replacement. Like most of the things we have, quality is based on cost. If you really want a good gauge, look for a Wika or Marsh. Those are 2 of the better gauges that come to mind. There are others but my mid didn’t bring them to the surface this morning. Yes they wear out.
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2231 days
#4 posted 02-10-2014 05:26 PM
yeah mine fail alot i just get new ones
#5 posted 02-10-2014 05:27 PM
I may buy a six pack on ebay. I’ve been acquiring more
and more machines that use air to operate and have gauges
vulnerable to damage.
View bigblockyeti's profile
bigblockyeti
5086 posts in 1683 days
#6 posted 02-10-2014 10:37 PM
Most gauges you’re likely to use at home aren’t going to be serviceable. Industrial machinery operating within tight pressure tolerances could have calibrated gauges that would have serviceable parts, but in my experience they are very expensive. The bourdon tube inside the gauge tries to extend with pressure inside and relaxes when pressure is relived, this movement over time causes fatigue in the metal and they will loose their precision. Better ones last longer, cheaper ones don’t.
