When to dial down speed on VS ROS?
Forum topic by JCantin posted 02-10-2014 01:30 PM 943 views 0 times favorited 5 replies Add to Favorites Watch
View JCantin's profile
JCantin
179 posts in 3650 days
02-10-2014 01:30 PM
Topic tags/keywords: ros
When is it recommended to dial down the speed on an ROS?
I can see the value if you are trying to remove epoxy or something you don’t want to melt but ff you are doing routine sanding to 220 to get ready for finishing is there any reason not to run at close to full speed?
5 replies so far
View pmayer's profile
pmayer
1032 posts in 3303 days
#1 posted 02-11-2014 01:39 AM
I also turn mine down sometimes when I am doing delicate work like rounding over an edge on softer wood, or sanding a small item that I need to hold in my hand and place against the sander. It’s a feature that I didn’t think I really needed, but I use more that I would have guessed.
View CharlesA's profile
CharlesA
3358 posts in 2035 days
#2 posted 02-11-2014 02:18 AM
I tight basic rule of thumb: lower grit, lower speed; higher grit, higher speed. I don’t follow this religiously, but I do tend to increase the speed as I move up in grit.
View Jim Finn's profile
Jim Finn
2688 posts in 3160 days
#3 posted 02-11-2014 03:26 AM
As Paul does, I use the slower speed when saning small hand held pieces.
-- No PHD just a DD214 Website> craftingcouple.com
View mikeevens45's profile
mikeevens45
68 posts in 1814 days
#4 posted 02-11-2014 04:37 AM
depends on the wood and how fast you want material removed use the slower speed for softer wood or fine finish sanding but faster for finish removal with coarse grits
mike
-- as technology progresses, wood workers seem to regress...all my power tools and my favorite is a chisel and a hand plane
View Jake's profile
Jake
850 posts in 1869 days
#5 posted 02-11-2014 05:27 AM
That is very interesting CharlesA, I was doing some research on it a while back and unless I misunderstood what you said I found the exact opposite…
So personally, I go with 80 grit at speed 6 (which is the highest speed I have), 120 at 5, 180 at 4, 220 at 3, 320 at 2 and 400 at 1 (lowest speed)
Of course my ‘research’ was on the internet and you never know what you going to get there so. If anyone else could chime in that would be greatly appreciated because I also got a metric crapton of sanding to do.
-- Measure twice, cut once, cut again for good measure.
