Stanley 60 1/2 with a big mouth...I think that the sole insert been filed?
« back to Hand Tools forum
Forum topic by Bundoman posted 02-10-2014 05:20 AM 976 views 0 times favorited 6 replies Add to Favorites Watch
View Bundoman's profile
Bundoman
153 posts in 1643 days
02-10-2014 05:20 AM
All,
I have this beat around 60 1/2 that was very unloved when I got it. It is a bit of a franken plane that I pieced back together in the shop with a later depth adjust knob. It also chipped mouth. I hoped to get it functional enough for a user in those rougher projects. I am a little bummed though as it seems to have a large mouth. It isn’t immediately evident to me in file marks etc. but I am assuming that the mouth insert has been modified. Or, am I all wet and this is normal. In comparing it to my other adjustable block planes, it seems odd to me. It is the only 60 1/2 that I have so looking for your knowledge on this one. Thanks…
The toe hang over when full open.
This is fully closed.
Fully open
-- Brent
View Cgwendling's profile
Cgwendling
12 posts in 2495 days
#1 posted 02-10-2014 01:23 PM
You have to put a blade in it and set it to approximate cutting depth first. Then you can tell if it’s been opened too much.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2424 days
#2 posted 02-10-2014 02:46 PM
Perhaps the mouth insert has been replaced with the mouth insert of another similar plane, and it differs in size. That a nice chunk out of the bed there, maybe when that happened, the original insert was also damaged. Perhaps the fix was either to file back the insert, or replace it.
Bundoman
#3 posted 02-11-2014 01:23 AM
I really meant to have this picture of the blade loaded last night. This one really tells the tale of what I am asking. The tightest the throat will get with a light shaving and the gap is between 1/8 and 3/16 inch inch at this setting. I really am thinking that the insert may have been swapped or filed. The damage to the insert when the throat was chipped could be a viable reason. Sorry I left this picture out last night. Appreciate the thoughts and comments… Brent
-- Brent
Smitty_Cabinetshop
15380 posts in 2673 days
#4 posted 02-11-2014 01:32 AM
Yes, it’s been modified. Possibly the sole side was filed to lessen the appearance of that chip…
View Don W's profile
Don W
18791 posts in 2622 days
#5 posted 02-11-2014 01:34 AM
I’m pretty sure all of the Stanley inserts had a lip or step on them on the mouth end, which mean either yours have been filed flat or replaced like Ed said.
Bundoman
#6 posted 02-11-2014 02:22 AM
Thanks all for the input. The news is as I suspected. This old bugger is obviously not the best. You should have seen it when I got it! I will be on the lookout for a good replacement. I am not long on low angle block planes in the shop, so I was trying to force this one back into service for just a little longer. I see a lot of standard angle planes but the low angle models show up less frequently for me. A better one will come along if I am a patient grasshopper. Brent
-- Brent
