New to me Rigid R4511 ts shocked by the quietness
Forum topic by savan posted 02-10-2014 02:41 AM 934 views 0 times favorited 4 replies Add to Favorites Watch
View savan's profile
savan
97 posts in 2388 days
02-10-2014 02:41 AM
I picked up a new to me r4511 for $275 off CL. It’s in great condition and has what I consider an insignificant chip on the top.
My only experience has been w/ 3 113 series saws I got off CL ranging from 0 to 50 dollars. I rebuild these and I thought they were both fairly quiet compared to the Bosch 4000 I had.
when I picked it up I thought to myself:
1. Damn this is heavy
2. after he started it, WHAT TYPE OF WITCHCRAFT IS THIS?
I was astonished to hear only the whirring sound of the blade.
Considering I sold my 113 w/ the fence from the rigid for $200 I think I got off pretty well.
My only concern now is how much of a pain it is going to be to aligning it, particularly the 45* setting…After owning 4 used saws I’ll never trust that a new to me saw is aligned.
I can’t wait to set it up and see what I’ve been missing!
View knotscott's profile
knotscott
8012 posts in 3372 days
#1 posted 02-10-2014 10:04 AM
The blade to miter slot alignment should be pretty straight forward because the R4511 has cabinet mounted trunnions. Not sure how the 45° adjustment will go….they’re not usually too bad.
View bdresch's profile
bdresch
143 posts in 1604 days
#2 posted 02-10-2014 04:04 PM
Check this page out for procedure on aligning the top.
https://www.ridgidforum.com/forum/t25836/
You need a dial indicator to get it really close. I got mine to about 0.002” with the blade veritical and about the same with it at 45 degrees. Much easier to align than my old craftsman 113.
savan
#3 posted 02-10-2014 04:09 PM
thanks, I did some across that document in my research. looks like about the best reference available-
View toolie's profile
toolie
2121 posts in 2625 days
#4 posted 02-11-2014 01:17 AM
i read that ridgid document when the author first presented it on the ridgid forum. be advised, it works on cabinet saws AND contractor (trunions mounted to table undersides) saws.
