Lower wheel adjustment Rikon 10-325
Forum topic by Sandra posted 02-10-2014 01:05 AM 2534 views 0 times favorited 40 replies Add to Favorites Watch
View Sandra's profile
Sandra
7207 posts in 2071 days
02-10-2014 01:05 AM
Topic tags/keywords: bandsaw rikon
While overall, I’m quite happy with my Rikon 10-325, it has certainly pushed me past my comfort zone as far as mechanical ‘tinkering’ goes.
When I was first trying to re-saw, I thought my saw was bogging down, but one of the issues was that the belt was slipping off. By the time I figured that out, the belt had been damaged. I put it back on, and went back to work. It’s now much worse, and it ‘walks’ off the lower pulley rather quickly. Today’s shop time was a wash as far as the bandsaw was concerned.
The blade tracks well on the upper wheel, but is too far forward toward the door on the lower wheel. So after reading the manual and looking online, it appears that I need to
1- replace the damaged belt – am I right in saying that I can’t use a link belt?
2- Adjust the lower wheel
Any recommendations for replacement belt? And how much trouble can I get myself into adjusting the lower wheel.
I’m nervous about damaging the saw.
Thanks for any pointers.
-- No, I don't want to buy the pink hammer.
40 replies so far
View lightcs1776's profile
lightcs1776
4200 posts in 1650 days
#1 posted 02-10-2014 01:09 AM
Personally, I’d call Rikon to inquire about using a link belt. They should be able to give you the best answer.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
View JL7's profile
JL7
8661 posts in 2961 days
#2 posted 02-10-2014 01:16 AM
So it’s a flat belt, not a v-belt? The link belt would replace a v-belt…...
-- Jeff .... Minnesota, USA
View boxcarmarty's profile
boxcarmarty
16173 posts in 2355 days
#3 posted 02-10-2014 01:21 AM
Sandra, Check the alignment of your pulleys, the motor pulley in particular. Make sure the key has not slipped and your pulley is walking causing it to throw your belt…..
-- My mind is like lighting, one brilliant flash, then its gone.....
View JL7's profile
JL7
#4 posted 02-10-2014 01:22 AM
Pictures?? you know the rules…...
Sandra
#5 posted 02-10-2014 01:24 AM
Okay, going to get some pictures. Stand by.
You’ll all have to talk very…. slowly….. while you guys were taking apart ‘trannies’ I was learning to sew…
View DIYaholic's profile
DIYaholic
19620 posts in 2670 days
#6 posted 02-10-2014 01:29 AM
Sandra,
Bummer on the problems.
As far as the belt….
NO, you can’t use a link belt. You can only use a “Multyi-Vee” belt.
Whether those are available from a secondary supplier, I do not know.
I doubt that it is a proprietary belt design/length, but one never knows.
I haven’t played with adjusting the lower wheel, so no advice except….
If you do make adjustments, of course read the manual & search the internet for guidance, then….
1) make very minor adjustments, I mean miniscule (1/8 turn of nut at a time, check outcome)....
2) Only ONE adjustment at a time….
3) Make a record of what adjustments you will do, before you do them!!! This way you won’t forget, and will be able to “undo”, if needed.
Good luck!
Wish I could be of more help…..
boxcarmarty
#7 posted 02-10-2014 01:32 AM
Jeff, I think we’re too late. Randy broke it…..
View Dave's profile
Dave
11429 posts in 2835 days
#8 posted 02-10-2014 01:34 AM
This one I know zilch about.
View JL7's profile
JL7
#9 posted 02-10-2014 01:34 AM
And Sandra is talking about trannies…..
Sandra
#10 posted 02-10-2014 01:36 AM
1st picture – lower wheel – blade tracking too far forward
2nd pic – upper wheel, blade gullets in center
3rd picture – pulleys on lower wheel
4th picture – damaged belt
Sandra
#11 posted 02-10-2014 01:39 AM
Thanks Randy – I was hoping you’d chime in as a fellow Rikon owner. Good to know about the link belt. I found the Rikon instructions about adjustment, I just hope there’s nothing else I’m missing that I should do first.
View Mark E.'s profile
Mark E.
387 posts in 3738 days
#12 posted 02-10-2014 01:43 AM
Don’t have the 10-325, but I do have the smaller 10-305, 10”.
I had to adjust the bottom (drive) wheel on mine after installing the Carter Stabilizer. The adjustments are very straightforward and pretty simple. Take your time and adjust in small increments and you will be just fine.
Here is a pdf from Rikon that walks you through the process.
-- Mark
View JL7's profile
JL7
#13 posted 02-10-2014 01:43 AM
Cool….you got some good answers…..Good luck!
Sandra
#14 posted 02-10-2014 01:44 AM
Thanks folks. It’s on the to-do list for tomorrow. Will let you know.
Mark E.
#15 posted 02-10-2014 01:45 AM
What am I looking at in your 4th picture?
Is that belt inside out?
-- Mark
showing 1 through 15 of 40 replies
